Head nuts, Will any M10 nut work? |
krazykonrad |
Jan 5 2021, 08:25 AM
Senior Member Group: Members Posts: 1,128 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
It looks like the 4 cyl. head nuts are NLA from Porsche. The PET lists them as M10. Can I use M10 nuts from the local hardware store?
Thanks! Konrad |
Mark Henry |
Jan 5 2021, 08:41 AM
No, if you were closer I'd send you a set.
Used T4 head nuts are reusable. |
Shivers |
Jan 5 2021, 08:46 AM
Senior Member Group: Members Posts: 2,436 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
ARP used to make a set.
VaccaRabite |
Jan 5 2021, 09:07 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Thats interesting.
Why can't you use regular m10 nuts for the cylinder heads? Zach |
ClayPerrine |
Jan 5 2021, 01:09 PM
Life's been good to me so far..... Group: Admin Posts: 15,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Thats interesting. Why can't you use regular m10 nuts for the cylinder heads? Zach The M10 nuts for the heads are 15mm heads, and thicker. The ones at your local hardware store are going to be 17mm heads, and won't allow you to put a socket on them in the recesses in the cylinder heads. There are plenty of spares out there. Just hit up a VW wrecking yard with a screwdriver and a 15mm socket. Clay |
IronHillRestorations |
Jan 5 2021, 01:54 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I have a bunch of new ones that I had zinc plated. PM me if you want some.
They are 10mm tall. Attached thumbnail(s) |
stownsen914 |
Jan 6 2021, 03:49 PM
Senior Member Group: Members Posts: 916 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Are hardened nuts needs for head studs?
914e |
Jan 6 2021, 05:32 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
nathanxnathan |
Jan 6 2021, 06:54 PM
Member Group: Members Posts: 291 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
Hardware that has a part number that starts with N in the PET, you can use non VW parts. Other things like head nuts have a specific part number. You can find them still searching for "021 101 457."
The 914 PET doesn't list them but it's in the VW bus Parts book I have. |
bdstone914 |
Jan 7 2021, 11:21 AM
bdstone914 Group: Members Posts: 4,538 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
It looks like the 4 cyl. head nuts are NLA from Porsche. The PET lists them as M10. Can I use M10 nuts from the local hardware store? Thanks! Konrad https://dunebuggywarehouse.com/hex-nut-cyli...d-21101457.html This place appears to have them new. @krazykonrad |
bdstone914 |
Jan 7 2021, 11:23 AM
Hardware that has a part number that starts with N in the PET, you can use non VW parts. Other things like head nuts have a specific part number. You can find them still searching for "021 101 457." The 914 PET doesn't list them but it's in the VW bus Parts book I have. I have them in my PET version. Attached thumbnail(s) |
krazykonrad |
Jan 7 2021, 12:39 PM
The washers are still available from Porsche. You would think that they are some special heat-treated part or something, but the same part number pops up all over, including in the suspension.
nathanxnathan |
Jan 7 2021, 12:59 PM
Hardware that has a part number that starts with N in the PET, you can use non VW parts. Other things like head nuts have a specific part number. You can find them still searching for "021 101 457." The 914 PET doesn't list them but it's in the VW bus Parts book I have. I have them in my PET version. Ah nice, I see them now. (IMG:style_emoticons/default/smile.gif) |
90quattrocoupe |
Jan 7 2021, 01:21 PM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
Anyone know what the pitch is on these nuts?
Greg W |
bdstone914 |
Jan 7 2021, 01:32 PM
914e |
Jan 7 2021, 01:34 PM
mepstein |
Jan 7 2021, 01:40 PM
914-6 GT in waiting Group: Members Posts: 19,317 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The washers are still available from Porsche. You would think that they are some special heat-treated part or something, but the same part number pops up all over, including in the suspension. Most suspension washers are heat treated as well. Yea, I noticed some of the suspension lots are grade 10 instead of the usual grade 8 |
90quattrocoupe |
Jan 7 2021, 02:00 PM
Lo-Fi Version | Time is now: 11th June 2024 - 02:40 PM |
