krazykonrad
Jan 5 2021, 08:25 AM
It looks like the 4 cyl. head nuts are NLA from Porsche. The PET lists them as M10. Can I use M10 nuts from the local hardware store?
Thanks!
Konrad
Mark Henry
Jan 5 2021, 08:41 AM
No, if you were closer I'd send you a set.
Used T4 head nuts are reusable.
Shivers
Jan 5 2021, 08:46 AM
ARP used to make a set.
VaccaRabite
Jan 5 2021, 09:07 AM
Thats interesting.
Why can't you use regular m10 nuts for the cylinder heads?
Zach
ClayPerrine
Jan 5 2021, 01:09 PM
QUOTE(VaccaRabite @ Jan 5 2021, 09:07 AM)
Thats interesting.
Zach
The M10 nuts for the heads are 15mm heads, and thicker. The ones at your local hardware store are going to be 17mm heads, and won't allow you to put a socket on them in the recesses in the cylinder heads.
There are plenty of spares out there. Just hit up a VW wrecking yard with a screwdriver and a 15mm socket.
Clay
IronHillRestorations
Jan 5 2021, 01:54 PM
I have a bunch of new ones that I had zinc plated. PM me if you want some.
They are 10mm tall.
stownsen914
Jan 6 2021, 03:49 PM
Are hardened nuts needs for head studs?
914e
Jan 6 2021, 05:32 PM
QUOTE(stownsen914 @ Jan 6 2021, 02:49 PM)
Yes, finding the exact specification of hardness is not easy to find.
nathanxnathan
Jan 6 2021, 06:54 PM
Hardware that has a part number that starts with N in the PET, you can use non VW parts. Other things like head nuts have a specific part number. You can find them still searching for "021 101 457."
The 914 PET doesn't list them but it's in the VW bus Parts book I have.
bdstone914
Jan 7 2021, 11:21 AM
QUOTE(krazykonrad @ Jan 5 2021, 08:25 AM)
Thanks!
Konrad
https://dunebuggywarehouse.com/hex-nut-cyli...d-21101457.htmlThis place appears to have them new.
@krazykonrad
bdstone914
Jan 7 2021, 11:23 AM
QUOTE(nathanxnathan @ Jan 6 2021, 06:54 PM)
I have them in my PET version.
krazykonrad
Jan 7 2021, 12:39 PM
The washers are still available from Porsche. You would think that they are some special heat-treated part or something, but the same part number pops up all over, including in the suspension.
nathanxnathan
Jan 7 2021, 12:59 PM
QUOTE(bdstone914 @ Jan 7 2021, 09:23 AM)
Ah nice, I see them now.
90quattrocoupe
Jan 7 2021, 01:21 PM
Anyone know what the pitch is on these nuts?
Greg W
bdstone914
Jan 7 2021, 01:32 PM
QUOTE(90quattrocoupe @ Jan 7 2021, 01:21 PM)
@"Greg W"
1.5
914e
Jan 7 2021, 01:34 PM
QUOTE(krazykonrad @ Jan 7 2021, 11:39 AM)
Most suspension washers are heat treated as well.
Jan 7 2021, 01:40 PM
QUOTE(914e @ Jan 7 2021, 02:34 PM)
Yea, I noticed some of the suspension lots are grade 10 instead of the usual grade 8
90quattrocoupe
Jan 7 2021, 02:00 PM
QUOTE(bdstone914 @ Jan 7 2021, 11:32 AM)
1.5
Thank you.
