Transmission, Clutch release bearing guides |
Morph914 |
Jan 5 2021, 10:46 AM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
rjames |
Jan 5 2021, 10:58 AM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
There should be 2 of them.
brant |
Jan 5 2021, 10:59 AM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
you need these..
they often get reused, and then fall apart with age. but you need them. |
ClayPerrine |
Jan 5 2021, 11:00 AM
Life's been good to me so far..... Group: Admin Posts: 15,520 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Get new ones every time you do a clutch.
Clay |
Morph914 |
Jan 5 2021, 11:13 AM
Yay! More parts to buy. Thank you guys for chiming in
rhodyguy |
Jan 5 2021, 11:18 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The retaining clip for the pivot is spent too. Replace the small ballcup bushing while you're in there.
Morph914 |
Jan 5 2021, 11:51 AM
roundtwo |
Feb 2 2021, 03:44 PM
Member Group: Members Posts: 282 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
The retaining clip for the pivot is spent too. Replace the small ballcup bushing while you're in there. The retaining clip seems to be ok but I have replaced the ball cup. Thank you! Cheers, John Hello, I'm going through the same process. Any other items need to be replaced before mating to the engine?- Replacing items 5, 8 and 9. Is item #1 inside the transmission? Thanks, Todd |
914werke |
Feb 2 2021, 04:03 PM
"I got blisters on me fingers" Group: Members Posts: 10,141 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
While your in there ~
if you are cutting your flywheel vs new, consider you may need to shim the pivot ball out. |
Lo-Fi Version | Time is now: 10th June 2024 - 01:48 AM |
