Cylinder orientation, Does it make any difference? |
DavidSweden |
Jan 23 2021, 03:09 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Hello,
I have an AA 2056 cylinder set, there are cut outs on each side of the cylinder skirt, the cut outs are not the same on each side. Is there is a reason why the cut outs are a different and which way should the cut outs be orientated Thanks in advance |
Robarabian |
Jan 23 2021, 04:18 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
It is irrelevant that those cuts are different. The cylinders have to be next to each other, and the flat sides are the flat sides. Whether one is on one side or the other, it is the same. Both large cuts are toward the center of the engine, not the outsides. You cant install them any other way.
DavidSweden |
Jan 23 2021, 04:35 PM
It is irrelevant that those cuts are different. The cylinders have to be next to each other, and the flat sides are the flat sides. Whether one is on one side or the other, it is the same. Both large cuts are toward the center of the engine, not the outsides. You cant install them any other way. Thanks Robarabian, I feel pretty stupid after reading your reply, I should have seen that myself. |
Robarabian |
Jan 23 2021, 09:43 PM
Don't!! We all have to learn by asking questions. Sometimes, I look at something and should see the answer staring at me... and then someone else comes along and .... you just learn. The only dumb question is the one you don't ask my friend...
914Sixer |
Jan 24 2021, 08:00 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
There are NO dumb questions. It is all about learning. A lot of us are visual people and we have to see it first before we understand it.
iankarr |
Jan 24 2021, 10:17 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The fact that you observed a difference means you’re looking at these things the right way and being deliberate about your assembly. That’s the best way to be.
BeatNavy |
Jan 24 2021, 11:08 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
There are NO dumb questions. Oh yeah? Hold my beer...Give me a second....I'll come up with something (IMG:style_emoticons/default/smile.gif) Seriously, much better to ask. When I (successfully) built my 2056 a couple of years ago I followed Len Hoffman's sage advice after selling me the heads: ask questions, take your time, and shoot for no less than .040" deck height. |
Lo-Fi Version | Time is now: 11th June 2024 - 06:34 AM |
