Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,916 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Need not a have a functional blower and/or control levers but open to options on what's available out there for a reasonable price.
Sure, I could JB weld mine up but it would still be pretty crappy. (IMG:style_emoticons/default/sad.gif) My upper fresh air housing has been beaten up pretty bad. Cracked housing in a couple of places, one of the drain pipe tube outlets has been cracked off pretty close the the housing, missing spring clips to hold it together in two places, and in one, the plastic tangs themselves are broken off. Not concerned about quality of the foam gaskets. Can replace those easily enough. Let me know what you have and how much you need for what you have. |
Fosterjoejr |
Newbie ![]() Group: Members Posts: 1 Joined: 30-December 15 From: Dallas Texas Member No.: 19,502 Region Association: Southwest Region ![]() ![]() |
Need not a have a functional blower and/or control levers but open to options on what's available out there for a reasonable price. Sure, I could JB weld mine up but it would still be pretty crappy. (IMG:style_emoticons/default/sad.gif) My upper fresh air housing has been beaten up pretty bad. Cracked housing in a couple of places, one of the drain pipe tube outlets has been cracked off pretty close the the housing, missing spring clips to hold it together in two places, and in one, the plastic tangs themselves are broken off. Not concerned about quality of the foam gaskets. Can replace those easily enough. Let me know what you have and how much you need for what you have. PM sent. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,542 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Need not a have a functional blower and/or control levers but open to options on what's available out there for a reasonable price. I Sure, I could JB weld mine up but it would still be pretty crappy. (IMG:style_emoticons/default/sad.gif) My upper fresh air housing has been beaten up pretty bad. Cracked housing in a couple of places, one of the drain pipe tube outlets has been cracked off pretty close the the housing, missing spring clips to hold it together in two places, and in one, the plastic tangs themselves are broken off. Not concerned about quality of the foam gaskets. Can replace those easily enough. Let me know what you have and how much you need for what you have. @Superhawk996 I have at least one. PM me your email for a picture. |
bdstone914 |
rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
I posted some pics of parts I have here:
http://www.914world.com/bbs2/index.php?sho...l=fresh+air+box |
Superhawk996 |
Found.
Thank you to all those that responded with various options. (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 10:34 PM |
