WTB: Longer spare tire hold-down bolt |
BillC |
Feb 19 2021, 08:56 PM
Senior Member Group: Members Posts: 541 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
I got a new spare tire this afternoon, and my current hold-down bolt no longer reaches. It's just a little bit shy of engaging the threads in the socket on the floor.
The bolt I have is 75mm (3 inches) from the bottom of the flange to the tip (10x1.5 thread). Does anyone have one that is about 13-19mm (1/2"-3/4") longer? Did Porsche even make such an item? Please let me know what you have. Thanks! |
frankiec@outrageous.net |
Feb 19 2021, 10:00 PM
Member Group: Members Posts: 81 Joined: 31-March 13 From: Mendocino, CA Member No.: 15,717 Region Association: Northern California |
I just went with a longer bolt, with the wider rims, without the handy wings to tighten and loosen on the stock bolt.
scallyk9 |
Feb 19 2021, 10:24 PM
Member Group: Members Posts: 323 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
Interesting question but I suspect Porsche did have different sizes as I've got two lengths here. I suspect the longer one had come with my LE that uses a 5th Mahle wheel as the spare wheel.
bdstone914 |
Feb 20 2021, 09:48 AM
bdstone914 Group: Members Posts: 4,524 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Billc
I though there were only two lenghts until tecently. The 75mm lenght and a shorter one the came in early cars with 4.5" wheels. I am replating some parts for another member and this longer bolt was in there. It is only about 80mm so that may not help you. I bought some longer 10 mm studs and knurled thumb screws that i think are a better setup. You install the stud in the floor and lock it with a jam nut. Place the tire and plate over the stud. Then spin on the thumb screw. It is easier then blindly hunting for the threaded hole while the plate covers it. I still have them but need to find them if you want to go that route. Bruce Attached thumbnail(s) |
BillC |
Feb 20 2021, 10:57 AM
@Billc I though there were only two lenghts until tecently. The 75mm lenght and a shorter one the came in early cars with 4.5" wheels. I am replating some parts for another member and this longer bolt was in there. It is only about 80mm so that may not help you. I bought some longer 10 mm studs and knurled thumb screws that i think are a better setup. You install the stud in the floor and lock it with a jam nut. Place the tire and plate over the stud. Then spin on the thumb screw. It is easier then blindly hunting for the threaded hole while the plate covers it. I still have them but need to find them if you want to go that route. Bruce @bdstone914 I think the wingbolt at the top of your picture will work. My stock bolt juuuust misses the threads for the hold-down. Those few extra mm should work. Please send me a PM with cost (w/shipping) and payment info. My stock bolt looks exactly like the one at the bottom of your pic. |
bdstone914 |
Feb 20 2021, 12:29 PM
@Billc I though there were only two lenghts until tecently. The 75mm lenght and a shorter one the came in early cars with 4.5" wheels. I am replating some parts for another member and this longer bolt was in there. It is only about 80mm so that may not help you. I bought some longer 10 mm studs and knurled thumb screws that i think are a better setup. You install the stud in the floor and lock it with a jam nut. Place the tire and plate over the stud. Then spin on the thumb screw. It is easier then blindly hunting for the threaded hole while the plate covers it. I still have them but need to find them if you want to go that route. Bruce @bdstone914 I think the wingbolt at the top of your picture will work. My stock bolt juuuust misses the threads for the hold-down. Those few extra mm should work. Please send me a PM with cost (w/shipping) and payment info. This one is not mine. I will ask the other member if he wants to sell it. I am getting the parts zinc plated for him. @billc My stock bolt looks exactly like the one at the bottom of your pic. |
Lo-Fi Version | Time is now: 22nd May 2024 - 11:10 PM |
