burlybryan |
Member ![]() ![]() Group: Members Posts: 134 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None ![]() ![]() |
Wondering if starters are interchangeable between the years/engine types? If so, what's the preferred reman? At some point, I'll be replacing my 1.8 with a 2.0, but swapping the trans between the two. My current starter (on the 1.8), makes some very bad noises and is either toast or is chewing up the flywheel.
Thanks. Bryan |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,730 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Others will chime in, but I believe all 4cyl starters are pretty much the same.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,955 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I use to always take the 911 starters and alternators to our local battery shop for a rebuild. It usually took 2 days and $75-125 depending on parts needed but Unlike buying reman parts, I always knew it would fit perfectly. It's just another option.
yellowporky |
Member ![]() ![]() Group: Members Posts: 431 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California ![]() |
@bdstone914 sold me a rebuilt 911 starter for my 1.7 and it cranks fast.
Maybe he can chime in on the specs |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,023 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Wondering if starters are interchangeable between the years/engine types? If so, what's the preferred reman? At some point, I'll be replacing my 1.8 with a 2.0, but swapping the trans between the two. My current starter (on the 1.8), makes some very bad noises and is either toast or is chewing up the flywheel. Thanks. Bryan @burlybryan All 914 starters are the same. They are 3/4 hp compared to a 911 at 1 -1/4 hp. If you are running a high compression motor use a 911 or high torque starter. If you want a quality rebuilt 914 starter is have one for $125 plus shipping, no core needed. Stay away from rebuilds from commom FLAPS. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
-I like the 911 starter, but it's a big heavy brute.
-The stock 914 starter is good for most apps. I also use a local auto-electric service shop. -I have a Hi-Torque on my 3.0/6 high CR engine, works real good and pretty light compared to the stock offerings. |
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,737 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
I use to always take the 911 starters and alternators to our local battery shop for a rebuild. It usually took 2 days and $75-125 depending on parts needed but Unlike buying reman parts, I always knew it would fit perfectly. It's just another option. Me too, I took Mark’s suggestion on this approach a year ago and soooo much better than FLAPS lottery. That said - I have an awesome shop close by but same day service and better price and I know it fits. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,186 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Bosch SR-68X is the NEW version of the 911 1.5 hp starter. It is high torque and smaller in size than the previous version. It is not cheap though, about $300 without core.
Attached thumbnail(s) ![]() |
robkammer |
Member ![]() ![]() Group: Members Posts: 224 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: North East States ![]() |
I like the 'Do not strike with hammer' warning. Back in the day it would have been targeted at Ford mechanics
burlybryan |
Thanks for the input all!
Cheers, Bryan |
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,964 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
Mark Henry |
Bosch SR-68X is the NEW version of the 911 1.5 hp starter. It is high torque and smaller in size than the previous version. It is not cheap though, about $300 without core. Almost looks like a 996 starter (it's not the same number, I checked) I hope it's not the same motor as they suck. IMO they are under powered. Looks like the Hi-Torque starter. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,422 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I have been running the IMI high torque starter on both Betty's 4 cylinder and on the 4.0 engine for years. Never had a single problem with them. And no hot start relay needed.
On the six, I run the Bosch SR-68X. It is the current Porsche recommended replacement. It turns over that 2.0 T motor with authority. But I am looking for an original early 911/914-6 starter to put on it. Clay |
burlybryan |
Wondering if starters are interchangeable between the years/engine types? If so, what's the preferred reman? At some point, I'll be replacing my 1.8 with a 2.0, but swapping the trans between the two. My current starter (on the 1.8), makes some very bad noises and is either toast or is chewing up the flywheel. Thanks. Bryan @burlybryan All 914 starters are the same. They are 3/4 hp compared to a 911 at 1 -1/4 hp. If you are running a high compression motor use a 911 or high torque starter. If you want a quality rebuilt 914 starter is have one for $125 plus shipping, no core needed. Stay away from rebuilds from commom FLAPS. @bdstone914 Hi Bruce, I've tried contacting you via our PM conversation regarding the rebuilt starter, but have not received any acknowledgement from you. Please confirm. |
bdstone914 |
Wondering if starters are interchangeable between the years/engine types? If so, what's the preferred reman? At some point, I'll be replacing my 1.8 with a 2.0, but swapping the trans between the two. My current starter (on the 1.8), makes some very bad noises and is either toast or is chewing up the flywheel. Thanks. Bryan @burlybryan All 914 starters are the same. They are 3/4 hp compared to a 911 at 1 -1/4 hp. If you are running a high compression motor use a 911 or high torque starter. If you want a quality rebuilt 914 starter is have one for $125 plus shipping, no core needed. Stay away from rebuilds from commom FLAPS. @bdstone914 Hi Bruce, I've tried contacting you via our PM conversation regarding the rebuilt starter, but have not received any acknowledgement from you. Please confirm. @burlybryan Bryan, The starter will go today my UPS. The delay is that Paypal printing of UPS postage has been down for about a week and still is. i went on to the UPS site and printed it from there. You should have an email notification with the tracking number. Sorry for the delay. Bruce |
Lo-Fi Version | Time is now: 4th July 2025 - 01:53 PM |
