QUOTE(burlybryan @ Mar 18 2021, 08:53 AM)
Wondering if starters are interchangeable between the years/engine types? If so, what's the preferred reman? At some point, I'll be replacing my 1.8 with a 2.0, but swapping the trans between the two. My current starter (on the 1.8), makes some very bad noises and is either toast or is chewing up the flywheel.
Thanks.
Bryan
@burlybryan All 914 starters are the same. They are 3/4 hp compared to a 911 at 1 -1/4 hp.
If you are running a high compression motor use a 911 or high torque starter.
If you want a quality rebuilt 914 starter is have one for $125 plus shipping, no core needed. Stay away from rebuilds from commom FLAPS.
