Suggestions? |
Suggestions? |
Pursang |
Apr 1 2021, 06:21 PM
Member Group: Members Posts: 232 Joined: 19-January 13 From: Beaverton Member No.: 15,386 Region Association: Pacific Northwest |
I am looking for a way to secure that rubber soundproofing pad that fits against the passenger wall in the engine compartment. Those metal tabs at the top seem pretty useless. It looks like some adhesive might have been applied with a tube at some time but the years and the engine heat have broken that seal.
I was thinking about small bolts and grommets through those metal tabs but I am afraid that they would eventually just rip through the pad. Would you apply adhesive again and, if so, what brand? Any other ideas? (IMG:style_emoticons/default/confused24.gif) Thanks. |
bbrock |
Apr 1 2021, 06:59 PM
I am looking for a way to secure that rubber soundproofing pad that fits against the passenger wall in the engine compartment. Those metal tabs at the top seem pretty useless. It looks like some adhesive might have been applied with a tube at some time but the years and the engine heat have broken that seal. I was thinking about small bolts and grommets through those metal tabs but I am afraid that they would eventually just rip through the pad. Would you apply adhesive again and, if so, what brand? Any other ideas? (IMG:style_emoticons/default/confused24.gif) Thanks. It is supposed to be attached with large plastic buttons that insert into the firewall about 1/3 of the way down on the pad. Napa has them. Part number is 665-3116. The tabs just keep the top of the pad snug to the firewall but don't hold it up. |
bkrantz |
Apr 1 2021, 07:20 PM
914 Guru Group: Members Posts: 7,792 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
You might hear lots of push back on mounting the original pad or (or any pad) since it tends to trap water and accelerate rust. Whatever you do, make sure water can drain out the bottom.
rbzymek |
Apr 1 2021, 08:09 PM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
I found that the 3M spray adhesive works well in that application. Just spray the metal and the back of the pad. Once it gets tacky set in place.
ClayPerrine |
Apr 2 2021, 10:04 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You might hear lots of push back on mounting the original pad or (or any pad) since it tends to trap water and accelerate rust. Whatever you do, make sure water can drain out the bottom. (IMG:style_emoticons/default/agree.gif) I also worry that it will fall down and block the engine fan, leading to catastrophic overheating of the engine. So I just insulate on the inside. Clay |
mepstein |
Apr 2 2021, 10:20 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You might hear lots of push back on mounting the original pad or (or any pad) since it tends to trap water and accelerate rust. Whatever you do, make sure water can drain out the bottom. (IMG:style_emoticons/default/agree.gif) I also worry that it will fall down and block the engine fan, leading to catastrophic overheating of the engine. So I just insulate on the inside. Clay Ben had an issue on a six conversion when the engine side pad blocked off airflow and made the engine run hot. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:50 AM |
