Voltage regulator, Is there one specific to the 2.0? |
Morph914 |
Apr 6 2021, 07:20 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
Warren914 |
Apr 8 2021, 07:04 AM
Member Group: Members Posts: 93 Joined: 26-February 21 From: Nova Scotia Member No.: 25,265 Region Association: Canada |
My car has a Wells VR650. Direct solid state replacement. |
914Sixer |
Apr 8 2021, 11:20 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Be careful on reproductions, they do not always fit right. Some are prone to early failure.
Mark Henry |
Apr 8 2021, 11:24 AM
My rebuilder swears by the old points style regulators, he even opens them and adjusts the points. He's not a fan of the solid state regulators.
johnhora |
Apr 8 2021, 11:58 AM
Senior Member Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Nothing wrong with that one...they all look like that on the bottom side after years of use. That's a good one from Bosch with Germany mfg
try it out and see if you're getting approximately 14v at about 1k rpm you can take the tape (usually yellow) off and open it up and check the inside if you want. What I have found testing them is that some get hotter than others...don't touch that rusty part after it is running if will flat burn you... I think this is why so many of the relay boards are cracked in this are on the bottom and why there is a slot below the regulator to help cool the area. I found the new Bosch solid state ones to run cooler. I have a couple used Bosch ones listed if you need an extra one. |
Morph914 |
Apr 8 2021, 02:40 PM
Nothing wrong with that one...they all look like that on the bottom side after years of use. That's a good one from Bosch with Germany mfg try it out and see if you're getting approximately 14v at about 1k rpm you can take the tape (usually yellow) off and open it up and check the inside if you want. What I have found testing them is that some get hotter than others...don't touch that rusty part after it is running if will flat burn you... I think this is why so many of the relay boards are cracked in this are on the bottom and why there is a slot below the regulator to help cool the area. I found the new Bosch solid state ones to run cooler. I have a couple used Bosch ones listed if you need an extra one. Thank you, I’ll test this one out like you said. I found this one on line but the #s are not quite the same. It says it will work on a 914... it says NOS Cheers, John |
914Sixer |
Apr 9 2021, 06:24 AM
Sure is nasty to be NOS. Stick with the one you have.
Morph914 |
Apr 9 2021, 07:02 AM
johnhora |
Apr 9 2021, 07:54 AM
Seems like I remember that the last two digits in the PN are sometimes different.
They were usually made in Germany Spain and Brazil. Used on VW , BMW, MB and probably other makes. Same part. |
pcdarks |
Apr 9 2021, 06:01 PM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
My rebuilder swears by the old points style regulators, he even opens them and adjusts the points. He's not a fan of the solid state regulators. Points burn and oxidize Electromagnetic coils burn out. Solid state is much more precise and dependable. Time to move into the 21st century. |
Lo-Fi Version | Time is now: 7th June 2024 - 01:18 PM |
