Brake pressure regulator, early vs. late |
robkammer |
Apr 23 2021, 05:14 AM
Member Group: Members Posts: 179 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: North East States |
Hello all, rebuilding the brake system on my new to me, as yet not driven BB is getting to be a much more difficult process than it should be.
The pressure regulator I've been supplied looks like it may be from an early model and my car is a 74. Is there a difference or are the two models different in some way? I've not yet held it up to the car but it looks like it will bolt right on. Any input would be appreciated. I'll post pics when I get to my shop this afternoon Thanks! Attached image(s) |
IronHillRestorations |
Apr 23 2021, 05:19 AM
I. I. R. C. Group: Members Posts: 6,733 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I think they are all the same
mepstein |
Apr 23 2021, 05:22 AM
914-6 GT in waiting Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Just the brass fitting at the top is different.
iankarr |
Apr 23 2021, 07:02 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,482 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The early has two ports. Late has three. Or vice versa. My June 74 ravenna car has three (top, bottom and side). The bumblebee has two (top and bottom)
robkammer |
Apr 23 2021, 08:21 AM
Thanks all, it turn out I was mis-remebering. The two are identical. Now it only has not to leak like the last one I had rebuilt.
bdstone914 |
Apr 23 2021, 03:13 PM
bdstone914 Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Thanks all, it turn out I was mis-remebering. The two are identical. Now it only has not to leak like the last one I had rebuilt. @robkammer PET shows the different part numbers. I think they are not the same. I know one type is needed for 6 conversions to avoid an interferance problem. Attached thumbnail(s) |
mepstein |
Apr 23 2021, 03:46 PM
Thanks all, it turn out I was mis-remebering. The two are identical. Now it only has not to leak like the last one I had rebuilt. @robkammer PET shows the different part numbers. I think they are not the same. I know one type is needed for 6 conversions to avoid an interferance problem. The 914-6 regulator is different than the 4. I think the internal spring has a slightly different rate. I think it's the routing on the early 914-4 that makes it easier to install a six mount. I didn't have to change mine on my 3.2 conversion. Might also be engine mount dependent. |
Montreal914 |
Apr 23 2021, 06:58 PM
Senior Member Group: Members Posts: 1,595 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
For all your brakes need, contact Eric Shea at PMB performance. He will set you up.
Good luck with your nice car! (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 17th June 2024 - 09:10 AM |
