Another GB Front trunk springs 914.511.163.10 E or L $34.88 a set (reg $65), Closes TODAY 5.20.21 trunk springs in enamel like factory Also hinge bolts $3 each w/GB |
Mikey914 |
Apr 27 2021, 04:18 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes had the opportunity to make these ad very cost effectively. We are offering both the early and late front trunk springs finished in enamel just like factory (well kind of like factory).
What I mean by this is factory had them dipped and if you look closely there was a lot of excess paint. I think we did a better job. You be the judge. We made the early at a 7.5" coil and the late at 8.375" No that the factory only used one part number as they superseded them with the longer springs. From a manufacturing these I can tell you that the early has a higher tension load. This is probably why the late superseded it. Will have these ready to ship in less than 2weeks (being finished now) , so who's in? Attached thumbnail(s) |
dlee6204 |
Apr 27 2021, 04:47 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
Im in for a set
rfinegan |
Apr 27 2021, 05:37 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Yep I'm in for a set. 75 late
PanelBilly |
Apr 27 2021, 06:12 PM
914 Guru Group: Members Posts: 5,811 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
What years are early and late?
56kabrio |
Apr 27 2021, 06:23 PM
Member Group: Members Posts: 54 Joined: 1-December 05 From: Nashville, TN Member No.: 5,219 Region Association: None |
I’m in for a set as well, but also don’t know when the early / late change occurred.
Thanks Mack |
Mikey914 |
Apr 27 2021, 09:41 PM
Its my understanding that somewhere in 73 (I was thinking early 73) since they were superceded both will work.
bob164 |
Apr 28 2021, 12:08 AM
Member Group: Members Posts: 96 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
I'm in for a set of late ones.
Dobbsy |
Apr 28 2021, 12:24 AM
Newbie Group: Members Posts: 49 Joined: 22-May 14 From: West Midlands Member No.: 17,382 Region Association: England |
Early set for me please.
Mikey914 |
Apr 28 2021, 12:45 PM
Getting a set out to Doug today.
Let us know what you think. -Mark |
Luke M |
Apr 29 2021, 07:06 AM
Senior Member Group: Members Posts: 1,375 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
1 set of early and 1 set of late please. (IMG:style_emoticons/default/beerchug.gif)
914sgofast2 |
Apr 29 2021, 11:08 AM
Senior Member Group: Members Posts: 622 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I will take a set!
Mike D. |
maf914 |
Apr 30 2021, 04:25 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
One set of model late model springs, please. Thanks, Mark.
Mikey914 |
May 1 2021, 11:59 AM
These are the hinge bolts at $3 when you buy the springs. Thought I would add them in as you already have the spring off.
Biggles |
May 1 2021, 01:06 PM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
I'm in for one early set
orthobiz |
May 2 2021, 07:35 AM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Most of my cars have had the springs reset at the third (farthest) slot to cure a sagging front hood.
So, will the new late springs allow placing the spring closer to the pivot? Or would the new short springs work better to eliminate sag. Paul |
jim_hoyland |
May 2 2021, 07:57 AM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Most of my cars have had the springs reset at the third (farthest) slot to cure a sagging front hood. So, will the new late springs allow placing the spring closer to the pivot? Or would the new short springs work better to eliminate sag. Paul (IMG:style_emoticons/default/popcorn[1].gif) I was wondering the same thought. If someone has done this, tell us the outcome And Thanks 914Rubber for another needed part ! |
Mikey914 |
May 2 2021, 09:50 AM
The "early' shorter springs would jive you the additional tension you are looking for. They will have a higher preload.
Mikey914 |
May 3 2021, 10:22 AM
These will be done from finishing this Friday!
Can-Am |
May 3 2021, 01:04 PM
Newbie Group: Members Posts: 35 Joined: 20-November 07 From: Scottsdale, AZ Member No.: 8,360 Region Association: None |
I'd like 2 sets please, one early and one late.
Mikey914 |
May 10 2021, 01:54 PM
PMs going out tonight this will close the 20th.
Lo-Fi Version | Time is now: 3rd June 2024 - 06:17 AM |
