Any OEM design 911 muffler up to a 2.4L fit? |
Tdskip |
May 30 2021, 03:58 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
From the research I’ve done it appears that 2.4L and earlier 912 mufflers fit our /6 builds but I wanted to double check.
Thanks! |
ClayPerrine |
May 30 2021, 04:52 PM
Life's been good to me so far..... Group: Admin Posts: 15,498 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Any 911 muffler will fit with the /4 rear valence. If you have a six porthole valence, it will only work with a /6 muffler.
Retroracer |
May 30 2021, 05:35 PM
Senior Member Group: Members Posts: 614 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
...with @ClayPerrine . Also, if you're doing a GT tribute then no rear valence needed of course. BTW - do you need a muffler? I have a ceramic coated Tesh single outlet muffler sitting in storage. PM me if interested... - Tony |
Tdskip |
May 30 2021, 08:53 PM
Thanks for the responses and info.
Retroracer |
May 30 2021, 09:49 PM
Chris914n6 |
May 30 2021, 11:54 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Don't have a good pic but mine is a late 80s Carrera 1 in 1 out and stock -4 valance.
mb911 |
May 31 2021, 06:27 AM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
mepstein |
May 31 2021, 07:17 AM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
From the research I’ve done it appears that 2.4L and earlier 912 mufflers fit our /6 builds but I wanted to double check. Thanks! Tom, 912 mufflers do NOT fit any 911 or 914-6 application. Let me know if you need a stainless quiet tech muffler. This is a 912 muffler Attached image(s) |
ClayPerrine |
May 31 2021, 09:43 AM
From the research I’ve done it appears that 2.4L and earlier 912 mufflers fit our /6 builds but I wanted to double check. Thanks! Tom, 912 mufflers do NOT fit any 911 or 914-6 application. Let me know if you need a stainless quiet tech muffler. This is a 912 muffler One Exception. 1976 912E muffler will fit. It is the same part as a 2.0 914. |
914werke |
May 31 2021, 12:28 PM
"I got blisters on me fingers" Group: Members Posts: 10,116 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
One Exception. 1976 912E muffler will fit. It is the same part as a 2.0 914. NOPE (IMG:style_emoticons/default/dry.gif) Not the same. Similar but will not bolt up to any 911/914/6 solution nor the 914/4. The Body of the muffler is identical, the flanges are specific to the 912e one yrs only HE's. They are still 3 bolt attachment but upside down from the /4 mounting. |
mb911 |
May 31 2021, 12:49 PM
One Exception. 1976 912E muffler will fit. It is the same part as a 2.0 914. NOPE (IMG:style_emoticons/default/dry.gif) Not the same. Similar but will not bolt up to any 911/914/6 solution nor the 914/4. The Body of the muffler is identical, the flanges are specific to the 912e one yrs only HE's. They are still 3 bolt attachment but upside down from the /4 mounting. Correct (IMG:style_emoticons/default/agree.gif) |
Tdskip |
May 31 2021, 05:52 PM
Oh geez, there was a typo in my original post. I intended to write 911 hence the 2.4L reference.
In any case thanks for the responses and information! |
ClayPerrine |
Jun 1 2021, 08:36 AM
One Exception. 1976 912E muffler will fit. It is the same part as a 2.0 914. NOPE (IMG:style_emoticons/default/dry.gif) Not the same. Similar but will not bolt up to any 911/914/6 solution nor the 914/4. The Body of the muffler is identical, the flanges are specific to the 912e one yrs only HE's. They are still 3 bolt attachment but upside down from the /4 mounting. Correct (IMG:style_emoticons/default/agree.gif) I always thought it was the same muffler. I am going to check this out next time I am at my friend's shop. He has a 912E. Clay |
914werke |
Jun 7 2021, 10:16 AM
One Exception. 1976 912E muffler will fit. It is the same part as a 2.0 914. NOPE (IMG:style_emoticons/default/dry.gif) Not the same. Similar but will not bolt up to any 911/914/6 solution nor the 914/4. The Body of the muffler is identical, the flanges are specific to the 912e one yrs only HE's. They are still 3 bolt attachment but upside down from the /4 mounting. Correct (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/hijacked.gif) @mb911 Ben before I begin a exhaustive (see what I did there (IMG:style_emoticons/default/shades.gif) )search, I figure Ill ask the muffler expert. Do you know if the spacing / or tube inlet measurement is the same for the 914/4 & 912e muffler variants ? In other words if I mod a 914 2.0L banana to apply the correct flanges for the 912e will it attach / fit the 912e HE's? |
mb911 |
Jun 7 2021, 10:40 AM
One Exception. 1976 912E muffler will fit. It is the same part as a 2.0 914. NOPE (IMG:style_emoticons/default/dry.gif) Not the same. Similar but will not bolt up to any 911/914/6 solution nor the 914/4. The Body of the muffler is identical, the flanges are specific to the 912e one yrs only HE's. They are still 3 bolt attachment but upside down from the /4 mounting. Correct (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/hijacked.gif) @mb911 Ben before I begin a exhaustive (see what I did there (IMG:style_emoticons/default/shades.gif) )search, I figure Ill ask the muffler expert. Do you know if the spacing / or tube inlet measurement is the same for the 914/4 & 912e muffler variants ? In other words if I mod a 914 2.0L banana to apply the correct flanges for the 912e will it attach / fit the 912e HE's? They are not the same. 912e is about the craziest setup on the planet. They come in at an angle. Could it be modified to work ? Yes for sure. Would be a bunch of work. I could see that as a 8-10 hour project to ensure everything lines up , trial fit, weld etc. |
mepstein |
Jun 7 2021, 11:00 AM
One Exception. 1976 912E muffler will fit. It is the same part as a 2.0 914. NOPE (IMG:style_emoticons/default/dry.gif) Not the same. Similar but will not bolt up to any 911/914/6 solution nor the 914/4. The Body of the muffler is identical, the flanges are specific to the 912e one yrs only HE's. They are still 3 bolt attachment but upside down from the /4 mounting. Correct (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/hijacked.gif) @mb911 Ben before I begin a exhaustive (see what I did there (IMG:style_emoticons/default/shades.gif) )search, I figure Ill ask the muffler expert. Do you know if the spacing / or tube inlet measurement is the same for the 914/4 & 912e muffler variants ? In other words if I mod a 914 2.0L banana to apply the correct flanges for the 912e will it attach / fit the 912e HE's? They are not the same. 912e is about the craziest setup on the planet. They come in at an angle. Could it be modified to work ? Yes for sure. Would be a bunch of work. I could see that as a 8-10 hour project to ensure everything lines up , trial fit, weld etc. http://forums.pelicanparts.com/porsche-912...haust-912e.html People have done it but it’s not worth it to hire out to a pro. Buying new is cheaper. |
Lo-Fi Version | Time is now: 1st June 2024 - 05:33 AM |
