dash, help |
dash, help |
hndyhrr |
Jun 12 2021, 07:46 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
The Pumpkin is 1970. She has the center defrost vent. I need to change that vent as I broke it. I got the dash pad off. Looking at the inside about how many screws/bolts do I need to find to take out the dash as that is the only way to replace that stinking vent. I am also going to apply new dash material from 914 rubber along with new material for the front of dash where guages and switches are. Thanks guys and gals |
mepstein |
Jun 12 2021, 07:53 PM
914-6 GT in waiting Group: Members Posts: 19,312 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’m pretty sure you access it from the front trunk. Remove the air box to get at the two bolts or screws that hood it in place. Not a fun job.
I can take a pic of the area in my parts car if it helps. |
windforfun |
Jun 12 2021, 07:56 PM
Senior Member Group: Members Posts: 1,833 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
I’m pretty sure you access it from the front trunk. Remove the air box to get at the two bolts or screws that hood it in place. Not a fun job. I can take a pic of the area in my parts car if it helps. (IMG:style_emoticons/default/agree.gif) |
hndyhrr |
Jun 12 2021, 08:01 PM
I’m pretty sure you access it from the front trunk. Remove the air box to get at the two bolts or screws that hood it in place. Not a fun job. I can take a pic of the area in my parts car if it helps. A Pic would be wonderful. But oh shit don't want to take air box out again! I see the bolts coming thru. Oh boy more fun. Thanks for info. |
bdstone914 |
Jun 12 2021, 08:11 PM
bdstone914 Group: Members Posts: 4,534 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The Pumpkin is 1970. She has the center defrost vent. I need to change that vent as I broke it. I got the dash pad off. Looking at the inside about how many screws/bolts do I need to find to take out the dash as that is the only way to replace that stinking vent. I am also going to apply new dash material from 914 rubber along with new material for the front of dash where guages and switches are. Thanks guys and gals Access is from inside of the car but nearly impossible without removing the sash frame. Held in by two flat head screws. @hndyhrr |
Lo-Fi Version | Time is now: 6th June 2024 - 03:20 AM |
