Pertronix HP 510 ignition box |
Geezer914 |
Jul 7 2021, 07:06 AM
Geezer914 Group: Members Posts: 1,447 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Wiring calls for a "run" wire. What can I tap into in the engine compartment?
Shivers |
Jul 7 2021, 07:29 AM
Senior Member Group: Members Posts: 2,431 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Relay board has ON OFF with the key, spots. I use one
Geezer914 |
Jul 7 2021, 10:40 AM
Picture of the terminal on the relay board?? Or pin number?
Shivers |
Jul 7 2021, 02:10 PM
roblav1 |
Jul 7 2021, 06:32 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I just put a Pertronix 510 in my -6 conversion last week. I simply connected the normal switched 12v+ coil wire to the thin red wire on the CDI. The CDI did not run my 1973 911S tach, even tried all 3 different wiring configurations. I have a Tach Adapt on the way now.
I hope you're changing the coil! You need a very low resistant one. |
Geezer914 |
Jul 8 2021, 05:52 AM
Thanks for the replies. Yes, I did get the Pertrinix coil they recommended.
Lo-Fi Version | Time is now: 10th June 2024 - 06:29 AM |
