Geezer914
Jul 7 2021, 07:06 AM
Wiring calls for a "run" wire. What can I tap into in the engine compartment?
Shivers
Jul 7 2021, 07:29 AM
Relay board has ON OFF with the key, spots. I use one
Geezer914
Jul 7 2021, 10:40 AM
Picture of the terminal on the relay board?? Or pin number?
Shivers
Jul 7 2021, 02:10 PM
QUOTE(Geezer914 @ Jul 7 2021, 09:40 AM)
Check how many amps you need. A couple places there
roblav1
Jul 7 2021, 06:32 PM
I just put a Pertronix 510 in my -6 conversion last week. I simply connected the normal switched 12v+ coil wire to the thin red wire on the CDI. The CDI did not run my 1973 911S tach, even tried all 3 different wiring configurations. I have a Tach Adapt on the way now.
I hope you're changing the coil! You need a very low resistant one.
Geezer914
Jul 8 2021, 05:52 AM
Thanks for the replies. Yes, I did get the Pertrinix coil they recommended.
