EJP914 |
Member ![]() ![]() Group: Members Posts: 273 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 ![]() |
Since I filled up the pedal box and most of the tunnel with brake fluid, looks like time for a new master cylinder.
I see 914 Rubber has two for sale. One they claim is "easy install". Has anyone tried this one? Are they a good source for master cylinders? I guess the question is how much of pain is it to install the "regular" cylinder. Have owned 4 914's in my lifetime. First time for this piece of work. Would appreciate any comments. Thanks EJP914 |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,953 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
It’s a pain to install a regular mc but it’s been done many thousands of times, even by me.
Many times a leaky mc will damage the pedal box bushings. They make new ones in bronze. |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,593 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
I used the 914 rubber easy one thanks to @mepstein whom sent it to me. It worked well once I was able to bleed it.
rudedude |
Senior Member ![]() ![]() ![]() Group: Members Posts: 521 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest ![]() ![]() |
I have two from from a group buy here that leak out the top plug. I would spend the extra dollars and put in an ate brand cylinder. And they can be a pain but plenty of good instructions here on how to do it
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,185 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
the cheap 90 dollar 19mm URO one works just fine
Since I filled up the pedal box and most of the tunnel with brake fluid, looks like time for a new master cylinder. I see 914 Rubber has two for sale. One they claim is "easy install". Has anyone tried this one? Are they a good source for master cylinders? I guess the question is how much of pain is it to install the "regular" cylinder. Have owned 4 914's in my lifetime. First time for this piece of work. Would appreciate any comments. Thanks EJP914 |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,168 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
I am about to undertake this project, thanks for posting. It looks straightforward, disconnect the lines, unbolt the old, bolt in the new connect the lines and go. Perhaps bench bleed prior to installing?
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,561 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
There are some threads for installing the feed lines on the regular style MCs. I used a tip on one of them to use a brake flare wrench (can't remember which size to pull the grommets down into the mc. It was actually quite easy with that little nugget of info. I recommend buying a set of OEM ATE grommets though. The grommets that came with the mc both leaked very slowly. I'm not sure there was anything really wrong with them but the ATE grommets felt stiffer and also gave a more satisfying feel as they seated properly in the bores.
willieg |
Member ![]() ![]() Group: Members Posts: 147 Joined: 13-August 18 From: Pleasant Hill Member No.: 22,389 Region Association: Northern California ![]() ![]() |
I have installed both types from 914Rubber and liked the easy install m/c better even though it cost a few bucks more.
Lo-Fi Version | Time is now: 1st July 2025 - 11:02 AM |
