WTB 2.0 Throttle Body, with or without TPS |
iankarr |
Jul 17 2021, 10:10 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
Anyone have a known-to-be-good, clean throttle body (not worn) for a 74 2.0? Thanks! Ian |
JamesJ |
Jul 17 2021, 03:07 PM
Member Group: Members Posts: 223 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Hi Ian,
Everyone has a different idea of what is meant by “worn”, so you may want to consider having it rebuilt. Phil Eslins advertises on The Samba and did mine. pbeslins@msn.com |
bdstone914 |
Jul 17 2021, 07:30 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hi Guys, Anyone have a known-to-be-good, clean throttle body (not worn) for a 74 2.0? Thanks! Ian I have cores and could send one to get rebushed if you dont find a tight one and want to keep your car together. @iankarr |
Steve H |
Jul 17 2021, 08:48 PM
Newbie Group: Members Posts: 28 Joined: 3-May 03 From: Los Angeles, Ca Member No.: 646 |
Hi Ian, Everyone has a different idea of what is meant by “worn”, so you may want to consider having it rebuilt. Phil Eslins advertises on The Samba and did mine. pbeslins@msn.com I just had my 74 2.0L throttle body rebuilt by Phil; finished yesterday. Phil sent a photo and said it would be shipped out today. It's beautiful but I should say, be prepared to wait a while. He definitely still has a following. |
iankarr |
Jul 17 2021, 11:01 PM
Hi Guys, Anyone have a known-to-be-good, clean throttle body (not worn) for a 74 2.0? Thanks! Ian I have cores and could send one to get rebushed if you dont find a tight one and want to keep your car together. @iankarr Thanks Bruce. It seems the TB that came with my bumblebee is pretty worn. When held up to a light I can see lots of light around the butterfly and the resting position of the spring assembly is partially open. The engine is running well, but the gaps in the TB are causing the idle to be 1900 or so. I've found no other vacuum leaks. So I basically can't drive the car until I have a good TB. How long do you think it would take to get one re-bushed? |
iankarr |
Jul 17 2021, 11:02 PM
Lo-Fi Version | Time is now: 10th June 2024 - 09:18 AM |
