Get to Okteenerfest, Yeah we can probably check off this list....... |
nditiz1 |
Aug 4 2021, 09:50 AM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So I just registered for Okteenerfest and I am hoping to bring the 914 GT and not the 911. Just need to take care of this short list (IMG:style_emoticons/default/unsure.gif)
Running list to be rdy for Okteenerfest Engine Attach chain covers Attach throttle linkage plate Attach fan to alt Attach alt to housing Attach air duct to housing Attach fan and shroud to engine Attach engine shroud Attach oil carrera tensioner lines Remove and replace rear main seal Attach flywheel Attach clutch Attach throttle bodies Attach linkage Attach fuel lines Attach vac lines Wire in megasquirt and alt Attach fan belt Install spark plugs Install coil packs Install ITB linkage Install headers Install muffler Install engine mount Mate engine to transmission Get engine to run and tune Car Welding minor patch in hell hole corner Mount brake thingy Mount brake lines Bleed brakes Cut holes for Oil tank Mount oil tank Install shift shaft Install engine and trans Fix trunk mount Install Backpad Install seats Install gauges Install wiper motor Install engine lid Install GT pull cable Who has a spare running engine I can barrow if this doesn't pan out, oh and a shift shaft since mine is now straight LOL |
mb911 |
Aug 4 2021, 12:00 PM
914 Guru Group: Members Posts: 6,886 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
That's a big list. You have a few fires to out out.
DRPHIL914 |
Aug 4 2021, 12:14 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
So I just registered for Okteenerfest and I am hoping to bring the 914 GT and not the 911. Just need to take care of this short list (IMG:style_emoticons/default/unsure.gif) Running list to be rdy for Okteenerfest Engine Attach chain covers Attach throttle linkage plate Attach fan to alt Attach alt to housing Attach air duct to housing Attach fan and shroud to engine Attach engine shroud Attach oil carrera tensioner lines Remove and replace rear main seal Attach flywheel Attach clutch Attach throttle bodies Attach linkage Attach fuel lines Attach vac lines Wire in megasquirt and alt Attach fan belt Install spark plugs Install coil packs Install ITB linkage Install headers Install muffler Install engine mount Mate engine to transmission Get engine to run and tune Car Welding minor patch in hell hole corner Mount brake thingy Mount brake lines Bleed brakes Cut holes for Oil tank Mount oil tank Install shift shaft Install engine and trans Fix trunk mount Install Backpad Install seats Install gauges Install wiper motor Install engine lid Install GT pull cable Who has a spare running engine I can barrow if this doesn't pan out, oh and a shift shaft since mine is now straight LOL wow it looks worse when you list it out like that, my motor is out of the car too. going to be close getting it put back together in time! i have not even split the case yet but hey its just a type4, pretty basic right? (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) |
nditiz1 |
Aug 4 2021, 12:39 PM
I am super optimistic (IMG:style_emoticons/default/biggrin.gif)
If I can get the engine sorted by End of August I might be in good shape. |
infraredcalvin |
Aug 4 2021, 01:41 PM
Distracted Member Group: Members Posts: 1,528 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I don’t know, that brake thingy can be tricky and super time consuming…
nditiz1 |
Aug 4 2021, 02:20 PM
Mark the chain covers off the list - just completed that (IMG:style_emoticons/default/biggrin.gif)
Brake thingy was for the brake valve regulator thing-a-ma-bob LOL |
Lo-Fi Version | Time is now: 11th June 2024 - 11:31 AM |
