So I just registered for Okteenerfest and I am hoping to bring the 914 GT and not the 911. Just need to take care of this short list
Running list to be rdy for Okteenerfest
Engine
Attach chain covers
Attach throttle linkage plate
Attach fan to alt
Attach alt to housing
Attach air duct to housing
Attach fan and shroud to engine
Attach engine shroud
Attach oil carrera tensioner lines
Remove and replace rear main seal
Attach flywheel
Attach clutch
Attach throttle bodies
Attach linkage
Attach fuel lines
Attach vac lines
Wire in megasquirt and alt
Attach fan belt
Install spark plugs
Install coil packs
Install ITB linkage
Install headers
Install muffler
Install engine mount
Mate engine to transmission
Get engine to run and tune
Car
Welding minor patch in hell hole corner
Mount brake thingy
Mount brake lines
Bleed brakes
Cut holes for Oil tank
Mount oil tank
Install shift shaft
Install engine and trans
Fix trunk mount
Install Backpad
Install seats
Install gauges
Install wiper motor
Install engine lid
Install GT pull cable
Who has a spare running engine I can barrow if this doesn't pan out, oh and a shift shaft since mine is now straight LOL
