worn hub washer |
worn hub washer |
JFG |
Aug 4 2021, 01:02 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
bdstone914 |
Aug 4 2021, 01:27 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Which side of the nut or bearing was contacting that surface?
What is under the washer ? Over tightening usually results in a burned up bearing. And what are gubbins ? |
914Sixer |
Aug 4 2021, 01:37 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Looks like bearing was not seated properly. Picture seems to show worn off at an angle? Is that correct?
JFG |
Aug 4 2021, 01:52 PM
Which side of the nut or bearing was contacting that surface? What is under the washer ? Over tightening usually results in a burned up bearing. And what are gubbins ? gubbins is generic for bits n bobs. the worn side was against the smaller outer bearing. There is no damage to the bearing or the housing. |
JFG |
Aug 4 2021, 01:54 PM
Looks like bearing was not seated properly. Picture seems to show worn off at an angle? Is that correct? it is indeed worn at a slight angle. the bearing is absolutely fine. I'm beginning to wonder if this was already like it when i got the car. freaking memory is pants. |
theer |
Aug 6 2021, 07:42 PM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
The hole in the center looks to be fubared. Should be nice & round except the nub. Maybe the wrong washer was used and “made to work”?
Shivers |
Aug 7 2021, 06:08 AM
Senior Member Group: Members Posts: 2,431 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Hi dude. I had looked up those washers, thinking I needed some. Not cheap. So I'd guess someone in the past had, like you said, over tightened it in the past. Not wanting or unable to get a new one they put that back in. I had to look where you were after "freaking memory is pants." , and the word gubbins. Great word
porschetub |
Aug 7 2021, 10:05 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hi dude. I had looked up those washers, thinking I needed some. Not cheap. So I'd guess someone in the past had, like you said, over tightened it in the past. Not wanting or unable to get a new one they put that back in. I had to look where you were after "freaking memory is pants." , and the word gubbins. Great word Love the Brits wording for things ,worked on ships with them and funny as. (IMG:style_emoticons/default/av-943.gif) . Anyway back to the program, that washer looks to be totaled so the bearing and the strut would be similar ,thinking I agree unseated bearing (IMG:style_emoticons/default/dry.gif) . |
arbitrary |
Aug 8 2021, 01:52 AM
Member Group: Members Posts: 81 Joined: 25-April 21 From: UK Member No.: 25,475 Region Association: None |
That almost looks like a strut top washer rather than a bearing washer?
Shivers |
Aug 8 2021, 05:16 AM
ctc911ctc |
Aug 8 2021, 07:44 AM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Anyone else wonder for a moment as to ‘bits and bobs’ Hi dude. I had looked up those washers, thinking I needed some. Not cheap. So I'd guess someone in the past had, like you said, over tightened it in the past. Not wanting or unable to get a new one they put that back in. I had to look where you were after "freaking memory is pants." , and the word gubbins. Great word Love the Brits wording for things ,worked on ships with them and funny as. (IMG:style_emoticons/default/av-943.gif) . Anyway back to the program, that washer looks to be totaled so the bearing and the strut would be similar ,thinking I agree unseated bearing (IMG:style_emoticons/default/dry.gif) . |
Lo-Fi Version | Time is now: 10th June 2024 - 06:24 AM |
