repairing flare/quarter, need suggestions |
bhfast |
Feb 6 2003, 12:20 PM
live it loud, balls out Group: Members Posts: 83 Joined: 30-December 02 From: Chandler, AZ/Daytona Beach, FL Member No.: 48 Region Association: Southwest Region |
ok, here's the deal. the car was in an accident(PO), and the LF flare was ripped off. i got a new flare(fiberglass BTW) and there is a gap between the flare and the fender. i was going to try make a new piece out of sheet metal, weld it on, then mount the new flare. then i got the idea to make a fiberglass mold off of another car and glass it all together. the pics might help.
Brian |
bhfast |
Feb 6 2003, 12:22 PM
front
bhfast |
Feb 6 2003, 12:23 PM
another
bhfast |
from the back
jonwatts |
Feb 6 2003, 12:40 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
I'm not a body man, I just hang around them from time to time.
I think if you try to make a fiberglass piece to fit that hole it will be susceptible to cracking at the joint. I would either put metal in or an entire fiberglass quarter. Someone out there (I can never remember which vendors sell which products) sells the entire quarter panel in fiberglass with the GT flare. That might be less work in the long run but might screw up the corner weights by just a few pounds. Finally, the driver's front fender is the last one to come off my car for Project: 2TERBOS (webpage coming soon!). I believe it's in pretty good shape, I can send pictures tonight. It's yours if you want it. Jon |
Brad Roberts |
Feb 6 2003, 01:29 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Jeez.
He is worse than me: Ranger pickup, Miata, Bike, 914, and a boat. Sorry I have nothing to offer wisdom wise. B |
Jeroen |
Feb 6 2003, 02:56 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Dunno, the gap isn't too clear to me (the replacement sheetmetal makes it hard to see how much is missing)
Unless you're confident you can recreate that shape in metal, I'd say glass it up Work from the inside out FWIW... Jeroen |
seanery |
Feb 6 2003, 03:14 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I have no experience at all in body work, but if it were my car I'd get another steel fender and attach the flare or fiberglass with flare installed for both sides.
The gap looks f'in huge to me! |
rick 918-S |
Feb 6 2003, 11:29 PM
Hey nice rack! -Celette Group: Members Posts: 20,473 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
You in a heap O' truble boy, That fender is toast. Do it right the first time and quite playin with it.
This is my recomendation. Buy a complete front fender. replace the whole thing. This will allow you to check panel fit, inner apron fit, and hood alignment. After you finish welding, cut the panel and fit the flare. |
GWN7 |
Feb 7 2003, 12:47 AM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
I agree with Rich. Easiest fix looks like fitting a new fender and starting from there. You will spend more time screwing around trying to patch that hole than you would putting a fender on. If you glass the whole area like it was mentioned b4... cracking. It looks like there isn't any metal to form the new glass area to, so you wouldn't have any strength. If you start welding metal patches (unless you have a fender top to weld in) you will spend more time shaping the bondo to make it match.....
Bleyseng |
Feb 7 2003, 12:53 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I'll have to vote to replace the fender too. Way easier to do that and you start with a clean surface and shape to attach the flare onto.
Geoff |
bhfast |
Feb 7 2003, 11:54 AM
ok, looks like new fender it is. jon, let me know when you get it off and how much you want for it.
Brian |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:24 PM |
