Heater / Heat Exchanger Delete, Block off fan shroud |
mtc911 |
Sep 11 2021, 03:47 PM
Member Group: Members Posts: 65 Joined: 18-March 18 From: Atlanta Member No.: 21,978 Region Association: South East States |
Previous owner rebuilt motor and removed heater - heat exchangers in lieu of a drive different exhaust / muffler combo. They had some heavy duty duct tape and tie wraps on on the (2) ports off the fan shroud. Those have worn off and now fallen off.
1 - it seems like I would want to keep these blocked off to help with cooling / air flow 2 - is there a more elegant way to block them off other than duct tape. Thanks. |
bdstone914 |
Sep 11 2021, 05:52 PM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Previous owner rebuilt motor and removed heater - heat exchangers in lieu of a drive different exhaust / muffler combo. They had some heavy duty duct tape and tie wraps on on the (2) ports off the fan shroud. Those have worn off and now fallen off. 1 - it seems like I would want to keep these blocked off to help with cooling / air flow 2 - is there a more elegant way to block them off other than duct tape. Thanks. It is better to leave them open. Blocking them off disrupts air flow in the shroud by blowing air into a dead end. In normal operation they are blowing air through the heat exchangers even when the heat is off. If it really bothers you take the shroud apart and block the openings inside the shroud. Maybe fill the holes with expanding foam. Are the J tube holes in the cylinder tin blocked off? I made up sets of plates to cover those holes as they allow hot air from below to be sucked in. @mct911 Attached thumbnail(s) |
mtc911 |
Sep 11 2021, 06:26 PM
Yeah. I blocked those holes off with some sheet metal. They were open when I got it and I was getting some high CHT readings. Thanks! Appreciate the help
Lo-Fi Version | Time is now: 1st June 2024 - 08:49 AM |
