| nditiz1 |
Sep 15 2021, 06:49 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,272 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region
I will be using the patrick motorsports linkage and I am already seeing an issue. The sheet metal from restoration design looks to be using the stock location for carbs which pushes the throttle closer to the center of the engine and has the ball on the inside. CIS throttle has it on the outside. I believe some needed to drill out the ball and tap it on the opposite side. Did they also need to drill a new hole? Did anyone get it working with less effort? Maybe just drill a hole further towards the outside of the engine and not mess with the ball on the throttle shaft. Show me what you did if you can, I'm a visual learner (IMG:style_emoticons/default/beer3.gif)
Thanks all! |
| Root_Werks |
Sep 15 2021, 08:41 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,072 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Here's a pic of my 2.7 with CIS. It uses a 4cyl cable. I cannot claim credit for the bracket. PO made a little bracket which allowed the use of the cable. Only mod on my part was drilling a hole in the 914-6 tin, adding a grommet for the cable to run through.
| Tdskip |
Sep 15 2021, 09:19 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Bump for even more pictures...and a thank you to @Root_Werks
| SirAndy |
Sep 15 2021, 09:52 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,539 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Search for the build thread of the late Jeff Tucker (Jeffs9146), he had tons of good info in there.
(IMG:style_emoticons/default/bye1.gif) |
| VegasRacer |
Sep 15 2021, 10:16 AM
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 9,131 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None
| nditiz1 |
Sep 15 2021, 10:48 AM
Thanks @SirAndy
@VegasRacer - John did you drill a new hole? Looks like everything is stock. Did you use the existing hole or drill a new one? |
| Cairo94507 |
Sep 15 2021, 10:53 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,780 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
VegasRacer and Root_Werks both have clean installs. (IMG:style_emoticons/default/beerchug.gif)
| VegasRacer |
Sep 15 2021, 11:06 AM
John did you drill a new hole? Looks like everything is stock. The PO did the conversion. (IMG:style_emoticons/default/smash.gif) No extra holes that I am aware of. |
| nditiz1 |
Sep 15 2021, 12:16 PM
Do you think you can get a shot of looking at where it passes through the rear engine tin?
| Root_Werks |
Sep 15 2021, 01:58 PM
I think you can use a 914-6 bell crank with most of the factory CIS linkage. It's super close to 914-6 carbs. There was one 914-6 CIS conversion I recall doing using a 914-6 bell crank and slightly modified rod. Turned out very nice and factory looking.
Only reason my 914-6 uses a 4cyl cable is because it was already done and works well. |
| nditiz1 |
Sep 15 2021, 03:47 PM
| VegasRacer |
Sep 15 2021, 11:18 PM
Do you think you can get a shot of looking at where it passes through the rear engine tin? This is the only photo I could find in my files of the rear engine tin. Attached image(s)
| Steve |
Sep 15 2021, 11:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,093 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
| VegasRacer |
Sep 16 2021, 12:47 AM
AMB Racing Transponder.
| ClayPerrine |
Sep 16 2021, 06:25 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
AMB Racing Transponder. ![]() Why would you put the transponder that far back in the car? You would want it on the front bumper... Just in case you go neck and neck with another car across the line. If he has his transponder on the front bumper, and you have it in the engine compartment, he is going to win because his transponder crossed the line first. Clay |
| ClayPerrine |
Sep 16 2021, 06:33 AM
Here are some pictures from an old thread on a CIS 914. The previous owner used an Audi airbox to replace the Porsche one, and that allowed it to fit in the 914 engine compartment.
(IMG:http://www.914world.com/bbs2/uploads/post-2-1129560305.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-2-1129560335.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-2-1129560365.jpg) The whole thread on the system is HERE. |
| VegasRacer |
Sep 16 2021, 09:41 AM
| nditiz1 |
Sep 16 2021, 10:32 AM
I just drilled a hole next to the factory throttle location. It should do the trick if I offset PMS throttle further towards the passenger side to line up perfectly.
| VegasRacer |
Sep 16 2021, 10:37 AM
Lo-Fi Version | Time is now: 15th October 2026 - 11:31 PM |
