fuel pump question |
Joec |
Sep 18 2021, 02:19 PM
Newbie Group: Members Posts: 16 Joined: 26-April 21 From: Delta, BC Member No.: 25,484 Region Association: None |
I am relocating the fuel pump to the front of the car below the gas tank. I am using a bosch fuel pump #69133. Will I need a fuel pressure regulator?
Dustin |
Sep 18 2021, 02:49 PM
Member Group: Members Posts: 111 Joined: 19-August 10 From: Woodland Hills, CA Member No.: 12,072 Region Association: None |
Is there some reason you think you wouldn't need a fuel pressure regulator?
You should have one already. |
Joec |
Sep 18 2021, 03:50 PM
The car hasn't run in many years, most of the fuel lines are missing but there is an aftermarket adjustable fuel pressure regulator on the car along with a gauge both which don't look like they belong. When I look at the 914 schematic of the fuel system I don't see a fuel pressure regulator. Is that because using a stock fuel pump would provide the proper pressure?
yellowporky |
Sep 18 2021, 05:04 PM
Member Group: Members Posts: 427 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
Carbs or stock fuel injection?
914werke |
Sep 18 2021, 05:20 PM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) Context!
jcd914 |
Sep 18 2021, 07:22 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The bosch pump #69133 is a high pressure fuel injection pump and you will need a pressure regulator.
If you are using carbs you need a different pump. If you are using a stock FI it would have had a pressure regulator at the driver side rear of the engine compartment, last component in the fuel loop on the engine. An aftermarket pressure regulator can be used if it has the proper pressure range. If you install a pressure gauge in the engine compartment make sure it is high quality, engine fires are nasty. Jim |
Joec |
Sep 18 2021, 09:01 PM
It is fuel injection
Joec |
Sep 18 2021, 09:04 PM
What should the fuel pressure be?
Suggestions for a pressure regulator? |
jcd914 |
Sep 19 2021, 12:14 AM
It depends on the fuel injection type, D-jet is 29 psi I believe and L-jet has 2 pressure checks, running at idle with vacuum hose connected and without the vacuum hose connected, I don't remember the specs. From your description it sounds like you will be going through the whole injection system. Good Luck Jim |
Joec |
Sep 19 2021, 09:49 AM
It is a 1974 2.0, D jetronic fuel injection I believe.
Joec |
Sep 19 2021, 12:23 PM
Found the oem pressure regulator, disconnected for some reason. Any reason not to use it? are they prone to failure?
Tdskip |
Sep 19 2021, 05:57 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Found the oem pressure regulator, disconnected for some reason. Any reason not to use it? are they prone to failure? Generally these are very reliable, now what has happen to your over the past 45+ years may be a different thing. You can always run it and check it with a pressure gauge. |
Lo-Fi Version | Time is now: 9th June 2024 - 03:18 AM |
