Turn signal relay |
Turn signal relay |
devil |
Sep 23 2021, 03:16 AM
Newbie Group: Members Posts: 8 Joined: 1-June 21 From: Estonia Member No.: 25,597 Region Association: None |
bzettner |
Sep 23 2021, 06:43 AM
Member Group: Members Posts: 211 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region |
I bought a 4 pin flasher relay from RockAuto last week made by Uro.
914Sixer |
Sep 23 2021, 06:45 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Hella does not make them anymore. Here you go, GERMAN made replacement.
Attached thumbnail(s) |
dr914@autoatlanta.com |
Sep 23 2021, 08:23 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we have always had plenty on the shelf, the relay works the turn signls, the emergency flashers, the handbrake light and the low brake circuit pressure light
Quite important to have the correct relay installed |
StarBear |
Sep 23 2021, 10:38 AM
Senior Member Group: Members Posts: 1,906 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Just a note: if you have a 1.8, the aftermarket ones more often than not don’t work right. Don’t know why. If you can, stick with NOS units. A member was selling used ones a few months ago. (IMG:style_emoticons/default/biggrin.gif)
dax1969 |
Sep 24 2021, 07:58 AM
Member Group: Members Posts: 362 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
I installed a Hella one recently and all of a sudden I got a buzzing noise and dim L/R arrows. Disconnected the wire on the brakeswitch and it stopped.
Still chasing the problem. Looking for a new relay that actually works. Prior to the hella one I tried to install a URO relay. Crap, that one just fell apart during install Difficult to find a good and correct one. Funny thing is that the wehrle one is made in germany but can't find them online in Europe while I see the all over ebay in the states. Crazy cheers Dax |
Steve |
Sep 24 2021, 09:06 AM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I also had to install an aftermarket one to get the spoke LED's to work correctly. All functions on my car work fine.
devil |
Sep 24 2021, 09:22 AM
we have always had plenty on the shelf, the relay works the turn signls, the emergency flashers, the handbrake light and the low brake circuit pressure light Quite important to have the correct relay installed Damn, I wish I had known to search Auto Atlanta – I just ordered a bushings kit from you, could have saved on the shipping (IMG:style_emoticons/default/smile.gif) Thanks for the info, will add it to my next order then. |
Quinn Moore |
Sep 24 2021, 11:40 AM
Qmoore Group: Members Posts: 108 Joined: 13-July 21 From: Fox River Grove, IL Member No.: 25,718 Region Association: Upper MidWest |
burlybryan |
Sep 24 2021, 01:26 PM
Member Group: Members Posts: 103 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
Just a note: if you have a 1.8, the aftermarket ones more often than not don’t work right. Don’t know why. If you can, stick with NOS units. A member was selling used ones a few months ago. (IMG:style_emoticons/default/biggrin.gif) I can attest to this. URO one didn't get along with my 1.8 car. |
Sep 24 2021, 01:30 PM
what I do best here at autoatlanta is give FREE and ACCURATE 914 tech advice. I am now making some YOUTUBE videos so that when I die the knowledge is not lost.
StarBear |
Sep 24 2021, 02:27 PM
914Sixer |
Sep 24 2021, 03:04 PM
Everyone SHOULD have a copy of DR 914 book. Lets you cut the the problem (IMG:style_emoticons/default/biggrin.gif)
Spoke |
Sep 24 2021, 06:15 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
You can always go with EP26 which is LED-compatible and pin-compatible.
Lo-Fi Version | Time is now: 1st June 2024 - 08:32 PM |
