Excess fuel in crankcase 914 1.8 |
68gator |
Oct 5 2021, 12:13 PM
Newbie Group: Members Posts: 3 Joined: 5-October 21 From: Seattle Member No.: 25,958 Region Association: None |
The car ran fine all summer. Just recently car started running real rich, plugs were horribly fouled, and when checking oil found lots of fuel in crankcase. Fuel regulator problem? The cold start valve has been inop since I have had the car (15 years), just lived without it. Thoughts please..
Dustin |
Oct 5 2021, 01:50 PM
Member Group: Members Posts: 111 Joined: 19-August 10 From: Woodland Hills, CA Member No.: 12,072 Region Association: None |
Leaking injector?
brant |
Oct 5 2021, 01:57 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I agree....most likely a leaking injector
or now leaking CSV |
68gator |
Oct 5 2021, 03:46 PM
When I checked the plugs to try and isolate one cylinder, all four plugs are really fouled, so it seams like it is more than just coming from one injector. There is lots of fuel in the crankcase, the oil level on the dipstick rises noticeably. I changed out the oil, and only drive it 2-3 miles, running rich, and I can see the oil level is higher each time.
jcd914 |
Oct 5 2021, 04:12 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Bad air flow meter?
The air flap gets bent and drags so it can hang up and add more fuel than needed. But also the fuel pressure regulator can leak and dump fuel into the intake through the vacuum line. Jim |
wonkipop |
Oct 5 2021, 06:13 PM
Advanced Member Group: Members Posts: 4,331 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
Bad air flow meter? The air flap gets bent and drags so it can hang up and add more fuel than needed. But also the fuel pressure regulator can leak and dump fuel into the intake through the vacuum line. Jim that sounds like a very good tip re fuel pressure regulator. simple as disconnecting the vacuum hose to see if anything is coming out. |
68gator |
Oct 5 2021, 07:17 PM
Bad air flow meter? The air flap gets bent and drags so it can hang up and add more fuel than needed. But also the fuel pressure regulator can leak and dump fuel into the intake through the vacuum line. Jim that sounds like a very good tip re fuel pressure regulator. simple as disconnecting the vacuum hose to see if anything is coming out. Thanks, I will check the flap so see if it moving freely. |
TheCabinetmaker |
Oct 5 2021, 07:36 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Does the 1.8 have a cold start valve?
L-Jet914 |
Oct 5 2021, 07:57 PM
Member Group: Members Posts: 238 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:03 AM |
