Clutch shafts |
Clutch shafts |
DLewis |
Oct 28 2021, 08:33 AM
Member Group: Members Posts: 63 Joined: 3-December 04 From: Poway, CA (was SF Bay area) Member No.: 3,212 Region Association: None |
I am rebuilding a pedal cluster for a member on the Pelican site with a 911.
He sent two clusters to make one and they had two different shafts. They are the same overall length. The one that is not straight on the end is from the 914. I think the straight one is from a 911 but I don't know what year. Also when you line up the holes where the roll pin goes they are offset slightly. So my questions are: Which one should I use If I go with the 914 one will it work in a 911 Thanks, Dean |
DLewis |
Oct 28 2021, 08:34 AM
914Sixer |
Oct 28 2021, 11:37 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Shaft is dependent on 911 year model. 911 changed pedal assembly in 1974. Prior to that it used the same one as the 914.
rudedude |
Oct 28 2021, 04:04 PM
Senior Member Group: Members Posts: 511 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
I just did this on a 72 911 and it has the straight one with the bushing. I wonder if it is due to the 915 transmission
bdstone914 |
Oct 28 2021, 06:49 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@dlewis Yes you can use the 914 shaft in the 911 pedal set if the 911 is 1968-1973. The 911's used either of the shafts you show. Not sure if the 911 shaft you show is the 74-76 shaft. You do have to use the spacer. |
DLewis |
Oct 29 2021, 07:19 AM
Thanks everyone.
His is a 72. I am going to ask if he has a preference. Dean |
Lo-Fi Version | Time is now: 9th June 2024 - 02:45 PM |
