Seat Position, Swapped Left To Right? |
windforfun |
Nov 18 2021, 01:13 PM
Senior Member Group: Members Posts: 1,835 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Do I have my seats in wrong? Given the different heights of the top back screws, did I install my seats incorrectly? Thanks.
Attached thumbnail(s) |
johnhora |
Nov 18 2021, 03:07 PM
Senior Member Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
You have them in correct placement....the seat rear thicker top part goes to the outside...if you go to the back of the car and look over the rear trunk into the rear window you will see that there is a curve downward to each outside....the top of the seat fills this space visually...looks good
windforfun |
Nov 18 2021, 05:49 PM
You have them in correct placement....the seat rear thicker top part goes to the outside...if you go to the back of the car and look over the rear trunk into the rear window you will see that there is a curve downward to each outside....the top of the seat fills this space visually...looks good Many thanks. You've a good eye!!! |
Root_Werks |
Nov 18 2021, 06:02 PM
Village Idiot Group: Members Posts: 8,334 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Dang, I never noticed that before. Learn something new everyday!
Jamie |
Nov 18 2021, 06:27 PM
Senior Member Group: Members Posts: 1,034 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
windforfun |
Nov 18 2021, 06:44 PM
Do I have my seats in wrong? Given the different heights of the top back screws, did I install my seats incorrectly? Thanks. I believe all driver seats have a L side notch for the handle of the hand brake. Mine doesn't, but there's a notch in the long for the handbrake. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
Dave_Darling |
Nov 18 2021, 08:08 PM
IIRC, the 72+ driver's seats have a divot for the handbrake. That's in addition to the notch in the long. Not sure about the seats in the early cars with the "floppy" handbrake handle.
--DD |
windforfun |
Nov 19 2021, 09:39 AM
Jamie |
Nov 19 2021, 11:31 AM
IIRC, the 72+ driver's seats have a divot for the handbrake. That's in addition to the notch in the long. Not sure about the seats in the early cars with the "floppy" handbrake handle. --DD My "73 seat doesn't have a divot. FYI. Cheers. But my '73 does, and seats are original! |
PCH |
Nov 19 2021, 02:30 PM
Member Group: Members Posts: 141 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California |
This doesn't address the seats. Sorry to hijack the tread but it looks like your engine lid has the same fit problem as mine. The lid at the front doesn't come all the way up to the rubber seal at the rear window.
I've looked at mine very closely, and I don't see any signs of repair of the hinges. Has yours had a repair? I'm beginning to wonder if some came from the factory like that after a suds filled lunch. |
windforfun |
Nov 19 2021, 02:57 PM
This doesn't address the seats. Sorry to hijack the tread but it looks like your engine lid has the same fit problem as mine. The lid at the front doesn't come all the way up to the rubber seal at the rear window. I've looked at mine very closely, and I don't see any signs of repair of the hinges. Has yours had a repair? I'm beginning to wonder if some came from the factory like that after a suds filled lunch. The lid is perfectly flush with the rubber seal (all the way up & touching). The seal looks blue from the reflected light. The lid is about 1/8" lower than the fixed side panels at the seal. One of the hinge mounts had to be welded because it was slightly loose (but not broken off). Happy Friday & speaking of suds... (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
rgalla9146 |
Nov 19 2021, 05:23 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
If you have no relief on the the left side of either seat you probably have two passenger seats. Early "floppy" hand brake cars had the relief too. |
windforfun |
Nov 19 2021, 06:08 PM
IIRC, the 72+ driver's seats have a divot for the handbrake. That's in addition to the notch in the long. Not sure about the seats in the early cars with the "floppy" handbrake handle. --DD You're correct. My driver's side seat does have a divot. I put a little more light on the subject, so to speak. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 05:52 AM |
