Only One Hi-Beam? (LED), Troubleshooting Help Please |
Nogoodwithusernames |
Dec 7 2021, 12:15 PM
Member Group: Members Posts: 239 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Over the Black Friday sale at 914 rubber I ordered their LED headlight kit and some LED gauge bulbs for the teener. Got those all installed over the weekend and all is working with the exception of hi-beams.
The driver side will turn on the hi-beam when the switch is pulled, but the passenger side goes completely dark and the indicator in the tachometer does not light up either. It did all work okay prior to LEDs so do I need to put a resistor inline somewhere? I emailed Scott over the weekend but haven't heard back yet so I am guessing they are keeping busy, thought I would come to you fine folks for some advise. Cheers! |
VaccaRabite |
Dec 7 2021, 02:59 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Each headlight has its own fuse for high and low beams. Look there first.
Zach |
JamesM |
Dec 7 2021, 04:30 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Check the wire orientation in the headlight connector. Had the same issue and found 2 of the wire were swapped on one side. System still worked fine with conventional bulbs but with LEDs one of the highs wouldnt activate until corrected.
Dave_Darling |
Dec 7 2021, 10:33 PM
That was my first thought! LEDs are "directional", and if you mix up the power and ground connections they won't light up at all. Unlike incandescent bulbs, which only care that current is flowing through them and not which direction.
--DD |
r_towle |
Dec 7 2021, 10:34 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Thing I learned today….led is directional…cool
VaccaRabite |
Dec 8 2021, 07:09 AM
Cairo94507 |
Dec 8 2021, 07:22 AM
Michael Group: Members Posts: 9,826 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
New to me too. (IMG:style_emoticons/default/smile.gif)
Dec 8 2021, 11:19 AM
Appreciate the suggestions, hadn't even thought of the wiring being backwards. Will double check that they are the same side to side since I have one side that works with hi and low beams I can compare against.
Fuses are a good place to check too. |
Mikey914 |
Dec 8 2021, 11:59 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
My money is wiring backwards.
Lo-Fi Version | Time is now: 10th June 2024 - 01:12 AM |
