> 6 cylinder engine removal, Advice needed
Dobbsy
post Feb 10 2022, 03:02 PM
Region Association: England
I have looked to see if this has been posted before but could not find a thread.
What is the best way to remove the engine and gearbox, is there a cradle like the one for the 4 cylinder.
Should I remove the heat exchangers first or can I use them for support.
mb911
post Feb 10 2022, 03:14 PM
QUOTE(Dobbsy @ Feb 10 2022, 01:02 PM) *
Heat exchangers are a perfect way to support the removal. I like to use either a piece of plywood on a jack or use a lift to raise the body above the engine while the engine is supported on blocks of wood.
post Feb 10 2022, 03:26 PM
914-6 GT in waiting
I like using a lift table. I unbolt the handle and lay it on the ground. It does require the car to be slightly higher but it makes life easy. The harbor freight 1000lb table is perfect.
post Feb 10 2022, 03:35 PM
Resident German
Not pretty, but functional ...
(IMG:http://www.914world.com/bbs2/uploads/post-179-1165172581.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1165172660.jpg)
Superhawk996
post Feb 10 2022, 04:04 PM
Shame Tangerine Racing doesn't offer a nice plate for /6. Maybe SirAndy willl offer a GB on the wood version. (IMG:style_emoticons/default/laugh.gif)
Tdskip
post Feb 10 2022, 04:48 PM
Harbor Freight lifting table makes it easy - just get the heavy duty one.
post Feb 10 2022, 05:32 PM
914-6 GT in waiting
QUOTE(Tdskip @ Feb 10 2022, 05:48 PM) *
It’s useful for so many things. Even a movable work table. They went up about $100 in the last year but still worth it.
johnhora
post Feb 10 2022, 05:41 PM
I agree with the group that the Harbor Freight heavy duty lifting table makes it easy
I also have a plate that I used originally for 911s..fits right under the engine and those holes are at the sump plate....works fine for 914 too....and then as mentioned the piece of plywood on a jack works fine especially if the HE's are on it as they make a nice flat bed...
Mark I also have modified my lift table so the arm folds to the outside/back so it doesn't get in the way and can be used for pulling.
Eric_Shea
post Feb 10 2022, 06:03 PM
PMB Performance
We have 3 of the lift tables. Install the handle backwards from the instructions.
infraredcalvin
post Feb 10 2022, 08:32 PM
Distracted Member
Factory tools, not cheap!
targa72e
post Feb 10 2022, 10:31 PM
I use 3 low profile jacks. Works for both 911 and 914. One goes at the balance point at engine/transmission and the other two to balance fan end of the engine using the headers/heat exchangers. This allows me to work the height front to back independently. I have started installing the engine without all the engine tins as the side metal is really tight between the control arm bolts. Mangled some tins really good first time I tried to install 6cyl in 914.
john
ClayPerrine
post Feb 11 2022, 08:07 AM
I just set the motor and trans on jackstands, and lift the car up.
But I have a 2 post lift.
Dion
post Feb 11 2022, 08:12 AM
RN
I took the left side tin off. A little more wiggle room around the suspension ears.
9146C
post Feb 11 2022, 08:18 AM
As already mentioned, with the HE's installed, it's a piece of cake.
I use 2-8's across a motorcycle lift. I've done this several times. Of late, once the motor is resting on the lift, I can jack up the car to get the clearance I need (not having a two post lift as some others). (IMG:style_emoticons/default/smile.gif)
brant
post Feb 11 2022, 08:37 AM
I prefer the lift
I have a wheeled platform for pulling the motor with jackstands
But prefer the lift
I reinforced this box. And added casters….
Lift the car
Lower the car onto the box
Pull 4 bolts and lift the chassis off the drivetrain
Roll drivetrain anywhere you decide
zoomCat
post Feb 11 2022, 09:16 AM
Does anybody have any experience using a QuickJack to drop a six?
mlindner
post Feb 11 2022, 01:40 PM
Dobbsy, I built a engine cradle to support engine while sending to a shop( bolts to exhaust studs and sit on case) but also worked great for the engine install. I have a scissor lift so I built a sturdy box with caster to support engine and trans, just rolled up under car and lowered lift and bolt up. Best, MarkAttached Image Attached ImageAttached Image
Dobbsy
post Feb 11 2022, 02:44 PM
Thanks for all the replies and photos,
I will make cradle at the weekend. I have already raised the car up on blocks and have the use of a fork lift, this will allow me to safely lower the engine / gearbox onto a trolley.
rgalla9146
post Feb 11 2022, 07:00 PM
What a bunch of sissies ! Way too fussy.
Just back up over a couple old tires.
East peasy! (IMG:style_emoticons/default/smile.gif)
bkrantz
post Feb 11 2022, 09:27 PM
QUOTE(rgalla9146 @ Feb 11 2022, 06:00 PM) *
I hope those are N-spec tires. (IMG:style_emoticons/default/biggrin.gif)
- Lo-Fi Version Time is now: 2nd March 2026 - 11:06 PM
