Trunk Light, WYZE motion sensing light |
jim_hoyland |
Mar 5 2022, 07:19 AM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Bought the WYZE motion sensing night lights for the bathroom originally. They are small, rechargeable, and have a magnetic back. They easily stick to any metal surface; they supply sticky-metal pieces for walls etc WYZE sells them on their website in packs of three.
Attached thumbnail(s) |
jim_hoyland |
Mar 5 2022, 07:37 AM
From their web page:
76-914 |
Mar 5 2022, 09:02 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Like!
Montreal914 |
Mar 5 2022, 11:38 AM
Senior Member Group: Members Posts: 1,571 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Neat! Thank you for sharing. (IMG:style_emoticons/default/smile.gif)
jim_hoyland |
Mar 5 2022, 12:20 PM
Originally, mounted one next to a gate lock; getting the key in at night was
hit-or-missi The light doesn’t stay on long and is discreet. Later, I mounted one in the bathroom so I would have just enough light to navigate. Then, the AHA moment; front trunk light for the 914 ! No wires required and the magnetic back makes it easy to reposition |
raynekat |
Mar 5 2022, 05:50 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Great idea.
barnfind9141972 |
Mar 5 2022, 10:27 PM
Member Group: Members Posts: 101 Joined: 10-December 20 From: Rancho Mirage, CA Member No.: 24,976 Region Association: Southern California |
@jim_hoyland awesome idea! Also where did you get that cover for the gas tank area? Looks great!
JamesM |
Mar 5 2022, 11:23 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I have similar magnetic motion sensing lights in my Vanagon that i use when camping.
Super handy! Never even thought about sticking one in a 914 trunk. |
jim_hoyland |
Mar 6 2022, 01:25 PM
@jim_hoyland awesome barnfind9141972 idea! Also where did you get that cover for the gas tank area? Looks great! @barnfind9141972 I made a paper template. Then transferred the pattern to this lightweight sheet foam. Either bought it from OSH of on-line. I may have a link, but a google seach on sheet foam should do the trick My cover have been 10 years of use; keeps the tank clean and stops those micro drafts from entering the cabin. |
jim_hoyland |
Mar 6 2022, 01:29 PM
@jim_hoyland awesome barnfind9141972 idea! Also where did you get that cover for the gas tank area? Looks great! @ barnfind9141972 I made a paper template. Then transferred the pattern to this lightweight sheet foam. Either bought it from OSH of on-line. I may have a link, but a google seach on sheet foam should do the trick My cover have been 10 years of use; keeps the tank clean and stops those micro drafts from entering the cabin. Seller: Foam Factory 586-627-3626 17500 23 Mile Rd Macomb, MI I bought a 1/2 sheet of 3/8” sheet foam Attached image(s) |
barnfind9141972 |
Mar 6 2022, 02:19 PM
@jim_hoyland awesome barnfind9141972 idea! Also where did you get that cover for the gas tank area? Looks great! @ barnfind9141972 I made a paper template. Then transferred the pattern to this lightweight sheet foam. Either bought it from OSH of on-line. I may have a link, but a google seach on sheet foam should do the trick My cover have been 10 years of use; keeps the tank clean and stops those micro drafts from entering the cabin. Seller: Foam Factory 586-627-3626 17500 23 Mile Rd Macomb, MI I bought a 1/2 sheet of 3/8” sheet foam @jim_hoyland awesome! Great trick, does it just stay in there because of the precise shape or did you use anything to hold it in place? |
jim_hoyland |
Mar 6 2022, 02:33 PM
@jim_hoyland awesome barnfind9141972 idea! Also where did you get that cover for the gas tank area? Looks great! @ barnfind9141972 I made a paper template. Then transferred the pattern to this lightweight sheet foam. Either bought it from OSH of on-line. I may have a link, but a google seach on sheet foam should do the trick My cover have been 10 years of use; keeps the tank clean and stops those micro drafts from entering the cabin. Seller: Foam Factory 586-627-3626 17500 23 Mile Rd Macomb, MI I bought a 1/2 sheet of 3/8” sheet foam @jim_hoyland awesome! Great trick, does it just stay in there because of the precise shape or did you use anything to hold it in place? It lays in place. Since it fits the contour of the space, it just sits there. When you make the paper template, you’ll see. |
barnfind9141972 |
Mar 6 2022, 05:41 PM
@jim_hoyland awesome barnfind9141972 idea! Also where did you get that cover for the gas tank area? Looks great! @ barnfind9141972 I made a paper template. Then transferred the pattern to this lightweight sheet foam. Either bought it from OSH of on-line. I may have a link, but a google seach on sheet foam should do the trick My cover have been 10 years of use; keeps the tank clean and stops those micro drafts from entering the cabin. Seller: Foam Factory 586-627-3626 17500 23 Mile Rd Macomb, MI I bought a 1/2 sheet of 3/8” sheet foam @jim_hoyland awesome! Great trick, does it just stay in there because of the precise shape or did you use anything to hold it in place? It lays in place. Since it fits the contour of the space, it just sits there. When you make the paper template, you’ll see. @jim_hoyland thank you! I’ll now have an illuminated trunk and a neat gas tank area! |
Lo-Fi Version | Time is now: 1st June 2024 - 08:37 PM |
