Advice Needed Installing Nose Cone |
poorsche914 |
Mar 31 2022, 07:15 PM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
I replaced the transmission nose cone gasket but am having a tough time getting the cone back on. Is there a secret to getting the small gear to align to the indent in the cone?
I recall years ago cracking the cone on one of these and don't really want to repeat that (IMG:style_emoticons/default/blink.gif) Thanks (IMG:style_emoticons/default/driving.gif) |
Superhawk996 |
Apr 1 2022, 08:03 AM
914 Guru Group: Members Posts: 5,915 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I only have 6 bits of advice.
1) Patience 2) Use a dab of grease to hold things in place. 3) The mating surfaces should be flat and mated before anything is tightened 4) Never force anything. Leave the BFH in the tool box. 5) Work on the trans in vertical orientation. Don't try to fight gravity. 6) Dr. Evil video |
mepstein |
Apr 1 2022, 08:29 AM
914-6 GT in waiting Group: Members Posts: 19,323 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
When it’s lined up properly, it just slides into place. Definitely no force is needed.
bdstone914 |
Apr 1 2022, 08:39 AM
bdstone914 Group: Members Posts: 4,542 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I replaced one with the trans in the car. Had to use a thin screw driver to get the reverse gear to align. Maybe test fit without the gear to make sure ther are no problems.
poorsche914 |
Apr 1 2022, 09:28 AM
If I remove the speedo gear drive unit, I can get the cone to fit down snug if I wiggle the stub axles a bit. But I am unable to insert the speedo drive unit at that point and, with the drive unit in place, cannot get the cone to drop into place.
This shouldn't be such a difficult task! (IMG:style_emoticons/default/headbang.gif) 1) Patience CHECK 2) Use a dab of grease to hold things in place. I THOUGHT OF THIS BUT DIDN'T KNOW IF IT WOULD HURT ANYTHING IN THE GEARBOX 3) The mating surfaces should be flat and mated before anything is tightened YEP 4) Never force anything. Leave the BFH in the tool box. AGREED 5) Work on the trans in vertical orientation. Don't try to fight gravity. CHECK 6) Dr. Evil video MIGHT BE OVERKILL FOR THIS PARTICULAR SITUATION (IMG:style_emoticons/default/confused24.gif) Thanks, all. I will try again this evening. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 04:19 AM |
