Washers for fuel tank pickup |
Kemo |
Apr 25 2022, 04:11 PM
Newbie Group: Members Posts: 12 Joined: 8-February 06 From: Austin, TX Member No.: 5,546 |
all,
im in the process of replacing my gas tank and the pickups underneath were somewhat mated to the old gas tank. a bit of heat helped, but the screen is toast on the supply side an ill be ordering another one. I kinda have a few questions here...does the supply side have a crush washer in addition to the screen? or does the screen body itself act as a crush washer? and does the crush washer go over the screen (seems like it would) I found a source for the screen that seems to include a washer (link) so the next question is the crush washer for the return line...I was not able to find this online, would anyone have a source for this size? its a bit smaller than the supply and didnt match up to any in my stache. Thanks! Steve Kennemer Austin TX |
Kemo |
Apr 25 2022, 04:13 PM
oh and here is a pic from another thread for reference on the return crush washer
(IMG:http://www.914world.com/bbs2/uploads_offsite/i188.photobucket.com-5546-1650925031.1.jpg) |
mgphoto |
Apr 25 2022, 04:55 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
The screen I recently purchased had the crush washer, tangerine racing.
Harbor Freight has a box of various size copper washers. |
maf914 |
Apr 25 2022, 04:58 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
It appears 914rubber may have the washer you need, but I'm not exactly sure. Check the link below and give them a call if you think that may be correct.
https://914rubber.com/fuel-strainer-screen-for-porsche-914 |
Costa05 |
Apr 25 2022, 07:16 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
I cut up some of my own washers from gasket material and used Hylomar Blue as a compound. It's been holding up well for so far. Found it recommended by others.
MM1 |
Apr 29 2022, 01:51 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
914 Rubber only had one with the screen recently.
AutoAtlanta has both correct washers -and I didn't have to anneal them. Not a drip so far. |
Lo-Fi Version | Time is now: 9th June 2024 - 03:32 AM |
