What's it called?, Cover under the fuel tank |
Quinn Moore |
Apr 29 2022, 07:46 AM
Qmoore Group: Members Posts: 108 Joined: 13-July 21 From: Fox River Grove, IL Member No.: 25,718 Region Association: Upper MidWest |
Good morning, trying to identify this cover. Mine is missing.
To access fuel lines under the gas tank from under the car. Haynes calls it a "gravel cover"......need to find one, once I know what to call it. (IMG:style_emoticons/default/blink.gif) (Picture is from the car that just came up on BAT) Thank for any help/direction. QM |
Superhawk996 |
Apr 29 2022, 08:02 AM
914 Guru Group: Members Posts: 5,900 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Download parts diagrams from Porsche Classic:
https://www.porsche.com/usa/accessoriesands...partscatalogue/ Restoration Design sells a nice reproduction & 914Rubber sells the seals |
Quinn Moore |
Apr 29 2022, 08:09 AM
Download parts diagrams from Porsche Classic: https://www.porsche.com/usa/accessoriesands...partscatalogue/ Restoration Design sells a nice reproduction & 914Rubber sells the seals Fantastic! Thank you. QM |
930cabman |
Apr 29 2022, 08:37 AM
Advanced Member Group: Members Posts: 3,147 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
"Protective plate" per the PET. Not too much protection here, it's 20 gauge steel
Superhawk996 |
Apr 29 2022, 08:59 AM
"Protective plate" per the PET. Not too much protection here, it's 20 gauge steel Not meant to be a skid plate. (IMG:style_emoticons/default/biggrin.gif) Simply designed to keep bottom of floor pan flat minimizing airflow disruption and to keep road debris off the steering rack and prevents debris from entering the area below the fuel tank through the large access hole. That is the "protective" element about it. |
Quinn Moore |
Apr 29 2022, 09:29 AM
Thank you, yes the plate is missing too. But, I'm looking for the round cover/plug. Looking at the first pic. Behind the round cover, are the fuel lines connected to the fuel tank.
(Looking at the pdf file now, tough time locating it. Quite extensive) QM |
914werke |
Apr 29 2022, 09:45 AM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
brant |
Apr 29 2022, 09:47 AM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
"Protective plate" per the PET. Not too much protection here, it's 20 gauge steel Not meant to be a skid plate. (IMG:style_emoticons/default/biggrin.gif) Simply designed to keep bottom of floor pan flat minimizing airflow disruption and to keep road debris off the steering rack and prevents debris from entering the area below the fuel tank through the large access hole. That is the "protective" element about it. works as a skid plate when necessary... this happened on ours (aluminum) when another driver pushed me off the track on a corner that had a very large drop off. to the original poster: I've never seen a "plug" on that hole in the picture you can see the welting that the factory used. yes those are the gas lines... protected from the sharp edge of the hole by welting you need the "skid plate" or "dust shield" or what ever you want to call it. brant Attached image(s) |
dr914@autoatlanta.com |
Apr 29 2022, 09:56 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
rack and pinion cover, we have new and used on the shelf, 914 341 161 00
Quinn Moore |
Apr 29 2022, 10:27 AM
Good morning, trying to identify this cover. Mine is missing. To access fuel lines under the gas tank from under the car. Haynes calls it a "gravel cover"......need to find one, once I know what to call it. (IMG:style_emoticons/default/blink.gif) (Picture is from the car that just came up on BAT) Thank for any help/direction. QM More pics might help. I am missing 914 341 161 00. But, in this instance I'm talking about the round hole.....(fuel tank has been removed for cleaning on my car). Thanks again, QM |
brant |
Apr 29 2022, 10:34 AM
its called welting.
its purpose is to cover the sharp edges of the hole. any wire that runs through a large hole, should always be protected think of it as a large grommet you cut it to length... can buy in bulk easily on line. I don't know if the factory part (welting) is sold... but any generic welting will serve the same purpose (sharp edge safety) and will not show when installed. try ebay... look up welting |
brant |
duplicate post
bkrantz |
Apr 29 2022, 08:04 PM
914 Guru Group: Members Posts: 7,803 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
yep, no cover or plug for that 4 inch diameter hole.
Rob-O |
Apr 29 2022, 09:32 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Yup, what everyone else said. There is no cover for that hole. In the picture you posted that you pulled from the internet, those 'pieces' you see inside the hole are not 'pieces' of a cover, they arer the two fuel lines.
Quinn Moore |
Apr 30 2022, 07:16 AM
Thanks everyone for the clarification! I "see" it now. The fuel lines as Rob-O pointed out. I will install the rack and pinion cover. Sorry for the goose chase, eyes aren't what they used to be. QM |
Front yard mechanic |
Apr 30 2022, 07:36 AM
Senior Member Group: Members Posts: 1,172 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Hand hole cover, or better known as 4" round switch plate cover at home depot
vitamin914 |
May 2 2022, 01:27 PM
Member Group: Members Posts: 202 Joined: 8-September 21 From: Toronto Canada Member No.: 25,893 Region Association: Canada |
There was another thread about this very hole. Not a solid cover but a ventilation mesh that fit perfectly, maybe from Home Depot too. It would keep the mice out and allow air to get in and out. The axle protective cover will still let mice get in there.
No matter what keywords I try I can't locate that thread with search... Anyone remember it? |
Lo-Fi Version | Time is now: 9th June 2024 - 06:18 PM |
