1970 pass seat removal |
Jimbo409 |
May 7 2022, 09:15 AM
Newbie Group: Members Posts: 16 Joined: 28-December 20 From: Illinois Member No.: 25,025 Region Association: None |
How do you remove the stationary pass seat on a 1970 model.it doesn’t slide forward
mepstein |
May 7 2022, 09:58 AM
914-6 GT in waiting Group: Members Posts: 19,296 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
4 nuts under the pad.
Edit - 6 nuts |
Jimbo409 |
May 7 2022, 10:09 AM
But how do I get to the rear nuts if the seat doesn’t slide forward,also does the middle section come out with passenger seat.it looks like it is all one piece
NotLance |
May 7 2022, 10:24 AM
Member Group: Members Posts: 69 Joined: 4-February 21 From: Northern California Member No.: 25,165 Region Association: Northern California |
The Passenger seat center cushion circled in blue in the first image comes out by pulling on the side closer to the backpad. It kind of levers out.
You can then remove the bottom part with the 2 side bolsters. Under the center cushion, there are 6 points it is connected to the floor, circled in blue Circled in red are the 2 points that were used to attach my center tray. |
mepstein |
May 7 2022, 10:38 AM
But how do I get to the rear nuts if the seat doesn’t slide forward,also does the middle section come out with passenger seat.it looks like it is all one piece Yes, the backpad is one piece. It includes the area behind the driver seat, middle pad and passenger seat back |
Jimbo409 |
May 7 2022, 05:49 PM
The Passenger seat center cushion circled in blue in the first image comes out by pulling on the side closer to the backpad. It kind of levers out. You can then remove the bottom part with the 2 side bolsters. Under the center cushion, there are 6 points it is connected to the floor, circled in blue Circled in red are the 2 points that were used to attach my center tray. Thank you |
Lo-Fi Version | Time is now: 28th May 2024 - 02:31 PM |
