> Front trunk/hood will not close
WizPorsche914
post May 17 2022, 10:58 AM
Help please my 71 Front trunk/hood will not close. I cannot get it to latch down fully.
I tried spraying WD-40 into the latch & you can hear the cable moving too. Any ideas ?
mgphoto
post May 17 2022, 11:08 AM
"If there is a mistake it will find me"
Take a Phillips screwdriver, push down on the catch of the lock mechanism to see if it will function. You may see that the catch is latched without the it engaging, just pull the handle to release.
Take a photo of the the mechanism.
WizPorsche914
post May 17 2022, 11:23 AM
Will do thanks !
QUOTE(mgphoto @ May 17 2022, 01:08 PM) *
Robarabian
post May 17 2022, 11:46 AM
914 A Roo
Sometimes when you pull the handle out to release it, it doesn't return all the way and the cable holds it open. Make sure you have pushed in the T handle all the way forward and then try to close it. Happens to me all the time.
WizPorsche914
post May 17 2022, 01:31 PM
Good idea thanks
QUOTE(Robarabian @ May 17 2022, 01:46 PM) *
Front yard mechanic
post May 17 2022, 04:16 PM
You have to many cases of German beer n there (IMG:style_emoticons/default/beerchug.gif)
WizPorsche914
post May 17 2022, 05:42 PM
Got it !! The latch part was stuck down once I popped it up with a screwdriver it worked fine.
WizPorsche914
post May 17 2022, 05:45 PM
QUOTE(Front yard mechanic @ May 17 2022, 06:16 PM) *
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
mgphoto
post May 17 2022, 06:46 PM
Now a little white lube, spray is easiest to apply.
WizPorsche914
post May 18 2022, 12:08 AM
Will do thanks.
QUOTE(mgphoto @ May 17 2022, 08:46 PM) *
- Lo-Fi Version Time is now: 15th April 2026 - 01:06 PM
