urgent part number needed |
JFG |
Jun 16 2022, 11:33 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
to help a german couple who have broken down.
They have a 73 2.0 model. the inner cv joint has failed. can someone confirm the part number and or what other models are the same. TIA |
brant |
Jun 16 2022, 11:38 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I don't have a part number
but the original joints were NLA for a long time and last I heard, porsche classic had them again but only sold a complete axle with 2 joints on it. It might have changed as I have not looked recently. the solution that people used when they were NLA were to buy the VW bug CV joint that was available. and drill it for the roll pin stud and maybe the gasket groove... these are sold often already modified by shops in the US a used joint is probably the quickest way... or find a shop in europe that sells the modified VW joint. brant |
JFG |
Jun 16 2022, 11:57 AM
thanks for the speedy reply. it looks as though they are going to have to ship a spare over here that they have at home.
sportlicherFahrer |
Jun 16 2022, 12:08 PM
Nothing to see here. Group: Members Posts: 1,088 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Edited: Please see info below from Superhawk996
Part number is 914-332-029-03. |
GeorgeKopf |
Jun 16 2022, 12:10 PM
Member Group: Members Posts: 172 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
According to the PET catalog.
All models have the same CV joint. 914 332 029 03 Good Luck George |
Superhawk996 |
Jun 16 2022, 12:12 PM
914 Guru Group: Members Posts: 5,876 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Another bit of info: The new CV's that Porsche is making can be found individually, but only fit the new axle shafts they are making. They changed the splines and do not fit original axle shafts. Part number is 914-332-029-03. Refinement to info above -- the part number above only fits 914/6 axles due to spline count difference. As previously stated, Porsche Classic was last selling complete axles with two of the CV's noted above and a reproduction of the 914/6 axle and splines. These complete axle assemblies will bolt on to a 914/4 as long as they purchase the complete axle assembly. |
Superhawk996 |
Jun 16 2022, 12:14 PM
According to the PET catalog. All models have the same CV joint. 914 332 029 03 Good Luck George The problem with PET is that it doesn't reflect what the idiots at Porsche Classic have done which is to use the /4 part number with the /6 spline count CV's they are now offering. Ask the poor guys like @bbrock that purchased that p/n from Porsche only to find it doesn't fit a /4 axle. I also notice they are now using the same axle part number for both 914/4 and 914/6 -- As built in the 70's, they were clearly different. I have a physical set of each -- never forget (IMG:style_emoticons/default/laugh.gif) I have also purchased the new CV's from Porsche and indeed they fit the 914/6 axle shafts. I suspect Porsche Classic knows little to nothing about 914's. We'll call it a revision of 914 history. Part differences between 914/4 and 914/6 are now down the memory hole (IMG:style_emoticons/default/av-943.gif) |
sportlicherFahrer |
Jun 16 2022, 01:16 PM
@Superhawk996 Thank you for the clarification! Edited my previous response.
dr914@autoatlanta.com |
Jun 16 2022, 01:31 PM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
buy the rebuilt axle plenty in stock
914werke |
Jun 16 2022, 02:19 PM
"I got blisters on me fingers" Group: Members Posts: 10,119 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
buy the rebuilt axle plenty in stock Covered before, NLA. I wouldn't usually advocate "throwing the baby out with the bathwater" but in this case you are probably best served by replacing the axle & getting both good CV's rather than risk the other (of likely equal vintage) to fail in short order. Othwerwise Id say: I have a NEW replacement CV's in stock HERE (IMG:style_emoticons/default/biggrin.gif) |
bkrantz |
Jun 16 2022, 07:34 PM
914 Guru Group: Members Posts: 7,792 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
According to the PET catalog. All models have the same CV joint. 914 332 029 03 Good Luck George The problem with PET is that it doesn't reflect what the idiots at Porsche Classic have done which is to use the /4 part number with the /6 spline count CV's they are now offering. Ask the poor guys like @bbrock that purchased that p/n from Porsche only to find it doesn't fit a /4 axle. I also notice they are now using the same axle part number for both 914/4 and 914/6 -- As built in the 70's, they were clearly different. I have a physical set of each -- never forget (IMG:style_emoticons/default/laugh.gif) I have also purchased the new CV's from Porsche and indeed they fit the 914/6 axle shafts. I suspect Porsche Classic knows little to nothing about 914's. We'll call it a revision of 914 history. Part differences between 914/4 and 914/6 are now down the memory hole (IMG:style_emoticons/default/av-943.gif) I went through that useless process twice, after Pelican posted a special listing for CVs, with a claim that they were correct for 914-4s. First order, wrong spline count. I returned those for exchange, with Pelican telling me they could get the right spline count with a special order from Germany. Turned out those were also wrong. |
Chaznaster |
Jun 17 2022, 05:47 PM
Member Group: Members Posts: 302 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
buy the rebuilt axle plenty in stock Covered before, NLA. I wouldn't usually advocate "throwing the baby out with the bathwater" but in this case you are probably best served by replacing the axle & getting both good CV's rather than risk the other (of likely equal vintage) to fail in short order. Othwerwise Id say: I have a NEW replacement CV's in stock HERE (IMG:style_emoticons/default/biggrin.gif) Rich's machined CVs are a good option based on my experience. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:13 PM |
