Steering Rack protective plate, Who sells the 17mm and 13mm bolts. Got to replace mine |
jim_hoyland |
Jul 18 2022, 04:47 PM
Get that VIN ? Group: Members Posts: 9,313 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The bolts are badly rusted and two have rounded heads.
Attached image(s) |
914Sixer |
Jul 18 2022, 04:52 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
ACE, Lowes, Home Depot. Make sure they are 8.8 or better.
NARP74 |
Jul 18 2022, 04:53 PM
Senior Member Group: Members Posts: 1,072 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
My local Ace hdw has metric. Online is Belmetric and another I can't remember right now.
914e |
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
Belmetric.
NARP74 |
Jul 18 2022, 04:55 PM
The local Ace has single parts in bins The Lowes and Home Depot went to bags of hardware and not much of a selection. By me anyway, YMMV.
jim_hoyland |
Jul 18 2022, 05:02 PM
Thanks ! Ace is the Place…., (IMG:style_emoticons/default/smile.gif)
jim_hoyland |
Jul 18 2022, 05:41 PM
What size bolt for the larger front bolt ?
bbrock |
Jul 18 2022, 06:43 PM
My local ACE is limited on metric, especially lengths. I usually can find something that will work, but isn't the exact right part. I usually look up the correct size in the PET and then order the exact match and finish through Belmetric.
nathanxnathan |
Jul 18 2022, 07:22 PM
Member Group: Members Posts: 283 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
jim_hoyland |
Jul 18 2022, 08:58 PM
914e |
Jul 18 2022, 09:19 PM
I think it is 9 and 6 that hold the cover on. The M12 x 80mm holds the support beam on and is a 19 mm head size.
nathanxnathan |
Jul 18 2022, 10:01 PM
I think it is 9 and 6 that hold the cover on. The M12 x 80mm holds the support beam on and is a 19 mm head size. Ah yeah that makes sense — I just checked my project and the bolts into the frame/car are 10 mm and the ones into the auxiliary support/crossmember are 8 mm. |
windforfun |
Jul 19 2022, 06:15 PM
Senior Member Group: Members Posts: 1,822 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
I think it is 9 and 6 that hold the cover on. The M12 x 80mm holds the support beam on and is a 19 mm head size. Ah yeah that makes sense — I just checked my project and the bolts into the frame/car are 10 mm and the ones into the auxiliary support/crossmember are 8 mm. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) Go with SS if you can & don't forget the lock washers. Flat washers may be necessary too depending on the cover holes. |
windforfun |
Jul 19 2022, 06:16 PM
jim_hoyland |
Jul 19 2022, 07:02 PM
Go with SS if you can & don't forget the lock washers. Flat washers may be necessary too depending on the cover holes. Done, Ace had everything. Problem now is to get the old bolts out. It’s awkward getting at them from the floor;the head of one M8 is wearing away plus a tough angle. Attached image(s) |
windforfun |
Jul 19 2022, 07:54 PM
Go with SS if you can & don't forget the lock washers. Flat washers may be necessary too depending on the cover holes. Done, Ace had everything. Problem now is to get the old bolts out. It’s awkward getting at them from the floor;the head of one M8 is wearing away plus a tough angle. Vice grips & maybe PB Blaster too. |
Lo-Fi Version | Time is now: 31st May 2024 - 08:20 PM |
