Caliper Rebuilds, Front 914 and front 911M |
jim_hoyland |
Aug 8 2022, 09:19 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Two questions;
1. After watching the PMB rear caliper rebuild, I’m curious what’s involved in the front rebuild 2. Do the front 914 and front 911M calipers use the same rebuild parts ? |
bbrock |
Aug 8 2022, 09:28 PM
PMB has you covered on how-to for rebuilding the fronts too: https://www.pmbperformance.com/brakehowto.html
Fronts are very easy compared to the rears. Not sure if the parts for 914 and 911M are the same, but PMB has rebuild kits. |
mgphoto |
Aug 9 2022, 10:56 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
911 and 914/6 have a larger piston than the 914/4 none of the parts are the same.
jim_hoyland |
Aug 9 2022, 02:56 PM
Lastly: are the 911M rear calipers different compared to 911M front calipers
If Yes, what physical characteristics tell which is which ? |
davep |
Aug 9 2022, 04:38 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
48mm 911 & 914/6 front
42mm 914 front 38mm 911 & 914/6 rear 33mm 914 rear |
jim_hoyland |
Aug 9 2022, 05:49 PM
Thanks
Lo-Fi Version | Time is now: 1st June 2024 - 07:30 PM |
