Can Injectors be Enlarged ?, ..how practical |
Literati914 |
Aug 21 2022, 09:10 PM
Senior Member Group: Members Posts: 1,475 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Can injectors be enlarged (2.0L green ones in particular) or "opened-up" to support a larger displacement engine?
I ask because I'm looking at a used set that was used with a supercharged engine - which also looks like it had a 944 throttle body (2.5L N/A I believe), running off stock 2.0L plenum via an adapter, etc.. but other details of the engine are un-known. These are definitely stock injectors, just want to be sure they're not modded (for my 2056/ 2.1 TB).. but don't even know if that's a thing. Maybe it was even probable? (IMG:style_emoticons/default/confused24.gif) Thanks. . |
barefoot |
Aug 22 2022, 06:37 AM
Senior Member Group: Members Posts: 1,280 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Can injectors be enlarged (2.0L green ones in particular) or "opened-up" to support a larger displacement engine? I ask because I'm looking at a used set that was used with a supercharged engine - which also looks like it had a 944 throttle body (2.5L N/A I believe), running off stock 2.0L plenum via an adapter, etc.. but other details of the engine are un-known. These are definitely stock injectors, just want to be sure they're not modded (for my 2056/ 2.1 TB).. but don't even know if that's a thing. Maybe it was even probable? (IMG:style_emoticons/default/confused24.gif) Thanks. . They're too complex for enlarging flow. You can, however increase fuel pressure to increase flow. Remember that follow is proportional too the square root of pressure. So if you want 10% more fuel flow you need to increase pressure by 21% (1.1squared) |
Literati914 |
Aug 22 2022, 07:50 AM
Thanks barefoot!
davep |
Aug 22 2022, 07:54 AM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I agree that modifying the injector would be very difficult. Two things are possible though. First is getting a similar injector with greater flow rate. Also, changing the injection pulse time to a longer duration; this might require changing the input parameters to the control box.
Lo-Fi Version | Time is now: 6th June 2024 - 09:54 PM |
