water bottle windshield washer hookup |
Medtner3 |
Aug 27 2022, 04:31 PM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
I feel like I am missing some parts .. I am ready to take on the dangerous task of hooking up my original windshield washer to the spare tire. I have replaced all the hoses, including the critical and risky hoses in the steering column , however the bottom of the washer bottle just has a black plastic nut and a small nipple at the bottom of the bottle ... am I missing a part?
Also, how does the hose hook up to the spare tire ... is there a special part for that as well? |
bbrock |
Aug 27 2022, 04:52 PM
The black plastic nut is the outlet that runs to the switch on the dash or steering column. Slip the nut over the hose, attach the hose to the nipple and then screw the nut on. It should hold tight. The other hose attached to the filler cap goes to the tire. The cap has a pressure valve inside that prevents the system from running your spare tire flat. Looks like you have everything there as far as bottle attachment goes. I haven't seen a bottle like that on a 914 though. Is it from a bug, or did they change the bottle for late year cars? (IMG:style_emoticons/default/confused24.gif)
Medtner3 |
Aug 27 2022, 06:28 PM
The black plastic nut is the outlet that runs to the switch on the dash or steering column. Slip the nut over the hose, attach the hose to the nipple and then screw the nut on. It should hold tight. The other hose attached to the filler cap goes to the tire. The cap has a pressure valve inside that prevents the system from running your spare tire flat. Looks like you have everything there as far as bottle attachment goes. I haven't seen a bottle like that on a 914 though. Is it from a bug, or did they change the bottle for late year cars? (IMG:style_emoticons/default/confused24.gif) thanks. How do you attach the hose to the spare? |
bbrock |
Aug 27 2022, 06:57 PM
The black plastic nut is the outlet that runs to the switch on the dash or steering column. Slip the nut over the hose, attach the hose to the nipple and then screw the nut on. It should hold tight. The other hose attached to the filler cap goes to the tire. The cap has a pressure valve inside that prevents the system from running your spare tire flat. Looks like you have everything there as far as bottle attachment goes. I haven't seen a bottle like that on a 914 though. Is it from a bug, or did they change the bottle for late year cars? (IMG:style_emoticons/default/confused24.gif) thanks. How do you attach the hose to the spare? It should have schrader hose barb to screw on to the schrader valve of the tire. If it is missing, you can use this: https://www.amazon.com/gp/product/B005DVE6Y...=UTF8&psc=1 |
pek771 |
Aug 27 2022, 08:18 PM
Member Group: Members Posts: 273 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None |
I have the same thing on my 914. IIRC from having a lot of VW's, the spare has a female Schrader in the plastic cap, which connects to a hose>dash switch>reservoir>window squirters. It is fairly stone-age relative to now.
Lo-Fi Version | Time is now: 11th June 2024 - 08:36 AM |
