Stock 17mm brake master cylinder -, No longer available? |
theer |
Sep 17 2022, 07:48 AM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Fellas,
I’ve scoured the interwebs for a stock 17mm MC. Loads of listings, but everyone appears to be out of stock. Have these been discontinued? Anyone know where to get one relatively quickly? Decent used would be fine. Alternately, anyone know of another similar sized (5/8”, 11/16” bore) Tilton, Wilwood (or whatever), which mounts to our pedal box? I know all about the 19mm MC from the 911- this quest is to reduce the pedal hardness back to stock. Thanks! Tom |
914Sixer |
Sep 17 2022, 07:54 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
They have been NLA for at least 10+ years. They appear from time to time.
Mikey914 |
Sep 17 2022, 10:24 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
No one is currently making them.
We made the 19 as it was more comnercially viable as it has 911 application too. You can look for rebuild kits they show up from time to time also. |
Superhawk996 |
Sep 17 2022, 10:47 AM
914 Guru Group: Members Posts: 5,903 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I know all about the 19mm MC from the 911- this quest is to reduce the pedal hardness back to stock (IMG:style_emoticons/default/cheer.gif) You’re on the right track. The engineers knew what they were doing when the system was designed with a 17mm master cylinder. Over time, the mythology takes over that the 19mm is somehow magical and better. . All it does is reduce pedal travel at the expense of increased pedal effort. There is no free lunch. I suspect everyone simply started pushing the 19mm m/c because that is all that they could get. Thus everyone began selling it as an “upgrade”. (IMG:style_emoticons/default/barf.gif) Keep looking - they can be found. As stated, rebuild kits can be found from time to time. I just found a 17mm NOS rebuild kit on Etsy of all places. Not in my hands yet but can’t wait to see if it is legit. |
914Sixer |
Sep 17 2022, 12:14 PM
I am setting on a NOS one , NOT for sale though.
904svo |
Sep 17 2022, 03:35 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Check with George at Auto Atlantic he had some new ones in stock.
Lo-Fi Version | Time is now: 10th June 2024 - 10:17 AM |
