Changing-out the deck lid hinges, Easy, hard, tips? |
campbellcj |
Sep 24 2022, 06:50 AM
I can't Re Member Group: Members Posts: 4,549 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Hi All -
I've got a "better safe than sorry" type of question re. swapping out the trunk lid hinges -- looking to install a set of Oscar's drilled & plated beauties. Is it tough to do this without hosing up the alignment/gaps? Do you do one side at a time and leave the other one in-place to hold the lid in the right position, along with a helper or two? Note I have GT style fiberglass lids which are pretty flexible and fragile though light. The springs are all removed. Thanks! |
mlindner |
Sep 24 2022, 07:32 AM
Senior Member Group: Members Posts: 1,530 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
chris, I would make some kind of template showing position of (witness) marks from the bolts and then transfer to Oscar's hinges. I have his fronts, love them. After final fit drill a small hole (finish nail) size through both hing and and trunk mounting fixture. Then can be removed and reinstalled dead on. Best, Mark
campbellcj |
Sep 24 2022, 09:57 AM
Thanks a bunch @mlindner I'll give it a shot next time my son is around to help out!
Lo-Fi Version | Time is now: 10th June 2024 - 06:09 PM |
