| StarBear |
Nov 11 2022, 03:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,264 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Another tact to my posting in the Classifieds for yellow zinc seatbelt anchor spacers might be to get the originals cleaned and replated.
Anyone here do such plating for two small parts? No need for a special run; can wait until a next scheduled run as I do have ones that will work, just not like factory OEM. (IMG:style_emoticons/default/smile.gif) Pic of current ones: ![]() |
| mepstein |
Nov 11 2022, 04:15 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,629 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I might have a couple already done. Give me the measurements for the washer and if I have some, I’ll send them to you.
| lesorubcheek |
Nov 11 2022, 05:31 PM
Member ![]() ![]() Group: Members Posts: 193 Joined: 21-April 21 From: Florida Member No.: 25,463 Region Association: South East States |
If you can't find any, I'd be happy to run them through my home-brew process. Been playing around with plating for a few months and still learning, so not perfect by any means, but hopefully good enough for use. Here's a brake caliper for reference. After cleaning, parts need a few strikes with zinc, then a dichromate dip for the gold color effect (and protection). Just let me know if you'd like me to give 'em a try.
Dan |
| StarBear |
Nov 11 2022, 06:14 PM
I might have a couple already done. Give me the measurements for the washer and if I have some, I’ll send them to you. @mepstein Great, Mark! O.D.= 28mm. I.D.= 12mm. Thickness = 4mm. |
| StarBear |
Nov 11 2022, 06:17 PM
If you can't find any, I'd be happy to run them through my home-brew process. Been playing around with plating for a few months and still learning, so not perfect by any means, but hopefully good enough for use. Here's a brake caliper for reference. After cleaning, parts need a few strikes with zinc, then a dichromate dip for the gold color effect (and protection). Just let me know if you'd like me to give 'em a try. Dan Dan; Very generous of you. Even if Mark has some (above) I’d be glad to let you practice and see how they turn out. A few others on the car can use replacing, too. (IMG:style_emoticons/default/dry.gif) Will PM you. |
| lesorubcheek |
Nov 11 2022, 07:14 PM
Dan; Very generous of you. Even if Mark has some (above) I’d be glad to let you practice and see how they turn out. A few others on the car can use replacing, too. (IMG:style_emoticons/default/dry.gif) Will PM you. More than happy to give'm a shot. Send whatever you'd like, as long as it's smaller that a brake caliper half, it'll fit in the cooler, er uh, chemical tank, that I rigged up for plating. I'm not gonna say what I used to plate the throttle cross member and rod since my wife may read these posts one day. (IMG:style_emoticons/default/biggrin.gif) Dan |
| stownsen914 |
Nov 11 2022, 07:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 999 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
There's a fellow over on the Pelican board that does small batches of plating. Shaun at Tru6 is his handle, I believe. Reasonable prices.
| rgalla9146 |
Nov 11 2022, 10:48 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,954 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Another tact to my posting in the Classifieds for yellow zinc seatbelt anchor spacers might be to get the originals cleaned and replated. Anyone here do such plating for two small parts? No need for a special run; can wait until a next scheduled run as I do have ones that will work, just not like factory OEM. (IMG:style_emoticons/default/smile.gif) Pic of current ones: ![]() Steve Wire brush till very bright. Do the same to all your dull steel fasteners and deliver to Quality Plating in Paterson, NJ I think it is called yellow chromate Talk to Mark Very reasonable. Rory |
| StarBear |
Nov 12 2022, 07:26 AM
Another tact to my posting in the Classifieds for yellow zinc seatbelt anchor spacers might be to get the originals cleaned and replated. Anyone here do such plating for two small parts? No need for a special run; can wait until a next scheduled run as I do have ones that will work, just not like factory OEM. (IMG:style_emoticons/default/smile.gif) Pic of current ones: ![]() Steve Wire brush till very bright. Do the same to all your dull steel fasteners and deliver to Quality Plating in Paterson, NJ I think it is called yellow chromate Talk to Mark Very reasonable. Rory Thanks, Rory! That’s a great contact to keep in my car support list stable. SR |
| gandalf_025 |
Nov 12 2022, 01:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,517 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
There's a fellow over on the Pelican board that does small batches of plating. Shaun at Tru6 is his handle, I believe. Reasonable prices. He does not do plating himself.. He is a middle man that provides the service and charges for his "Value Added" service of cleaning the parts before plating and then tumbling and polishing after.. His prices reflect his value added... |
| sixnotfour |
Nov 12 2022, 07:27 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,199 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
PMB does it Every Day..
| TonyA |
Nov 12 2022, 07:54 PM
Nachmal ![]() ![]() ![]() Group: Members Posts: 679 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
| lesorubcheek |
Nov 12 2022, 08:33 PM
Built this plating system but have not perfected the process yet. I’ll let you know. I plan on doing a bunch. Nice! (IMG:style_emoticons/default/rocking nana.gif) Dan |
| StarBear |
Nov 12 2022, 09:06 PM
| StarBear |
Nov 30 2022, 02:43 PM
I might have a couple already done. Give me the measurements for the washer and if I have some, I’ll send them to you. @mepstein Great, Mark! O.D.= 28mm. I.D.= 12mm. Thickness = 4mm. @mepstein Mark; any luck finding two nice ones (that’s what she said)? I found some near substitutes at the local hardware store and new ones are “significant back order”. The repeated ones turned out to be more pitted than realized. Thanks! |
| Van B |
Nov 30 2022, 07:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None
Steve-o,
I bought a caswell plating kit for my project. I’m not anywhere close to getting to plating, but I’d be happy to add your parts in when I get to it. But it will probably be a few months until I’m to that point (IMG:style_emoticons/default/wacko.gif) |
| nathanxnathan |
Nov 30 2022, 07:56 PM
Member ![]() ![]() Group: Members Posts: 294 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
I did some plating with a Caswell setup over the long weekend. It took a bit of failure to get to the point of being happy with the finish, but I did a lot of parts and they came out really awesome in the end. Most of what I did was mid sized stuff — a bunch of camber plates and rear shock/sway bar bolts, lug nuts, front turn signal housing brackets, front lid releases, pedal cluster stuff, and other misc stuff. Smaller stuff is going to be a challenge but I have a plan. Those washers would be easy. It helps to have a blasting setup imo.
Getting everything is a bit $$ — the kit, the power supply, and the heater notably, but with all the parts I've got ready to plate, having it done by a place would be a lot more and also it would be really hard to keep straight what goes to what hardware-wise. I have like 3 cars worth of stuff to plate and I got though about 1/3 of it so far. I need to get more of the Caswell zinc powder and the liquid, and I'm going to do another round of plating soon. |
| StarBear |
Nov 30 2022, 08:11 PM
Steve-o, I bought a caswell plating kit for my project. I’m not anywhere close to getting to plating, but I’d be happy to add your parts in when I get to it. But it will probably be a few months until I’m to that point (IMG:style_emoticons/default/wacko.gif) Van; Thanks. No rush for now as the close ones I got from the hardware store suffice, but not accurate size or thickness. Will stay in touch. |
| lesorubcheek |
Nov 30 2022, 08:37 PM
Steve allowed me to give it my best shot on these washers, but unfortunately after rust removal using diluted phosphoric acid, they were pitted badly. I did 4 layers of zinc, but it didn't help fill the pitting.
Unfortunately, with 914World dead, we had no way to communicate. I gave 'em a quick dichromate dip and just tried to get 'em back to Steve as quickly as possible. Really sorry they didn't turn out any better. I really don't know a solution to pitting other than grind it down, or build it up with welding and then grind, but that's getting pretty involved for washers. Hopefully some new ones will be available soon. Dan |
Lo-Fi Version | Time is now: 15th April 2026 - 01:38 PM |
