Type IV engine case preparation, Looking for information |
Driver174 |
Nov 12 2022, 01:33 PM
Member Group: Members Posts: 106 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
I have the desirable W case and want to prepare it for a future build. Is there a procedure or instructions written somewhere explaining how to prepare a case assembly?
I wouldn’t mind purchasing this information; maybe Mr. Raby offered something in the past? Thanks, Jim |
914Sixer |
Nov 12 2022, 03:07 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check line bore. Pull head studs and have case decked on barrel spigots. Visually check crankshaft and camshaft saddles for damage or out of round.
Driver174 |
Nov 12 2022, 04:15 PM
The oil passages get tapped and plugged, or welded shut. Oil pressure regulator valve assembly needs modified I believe. The rear main seal needs a pressure relief passage. Case needs clearances for Cr moly rods. Epoxy or some king of coating for interior and exterior of case.
I’m hopping to find a complete list processes to perform. |
barefoot |
Nov 13 2022, 11:01 AM
Senior Member Group: Members Posts: 1,281 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Using new main bearing inserts, see if they're a tight fit into the brg saddles, if loose at all, the case needs line boring to 1st O/S
930cabman |
Nov 13 2022, 12:30 PM
Advanced Member Group: Members Posts: 3,147 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Other than being clean and straight/flat and within spec, build her up
Lo-Fi Version | Time is now: 9th June 2024 - 10:59 PM |
