| friethmiller |
Nov 12 2022, 06:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,334 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
| URY914 |
Nov 12 2022, 06:47 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 133,770 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Is the pin loose in the hole?
| friethmiller |
Nov 12 2022, 07:51 PM
| rgalla9146 |
Nov 13 2022, 06:11 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,977 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Yes, too loose and too long. Too much play leads to even more play and likelihood of issues. |
| URY914 |
Nov 13 2022, 06:29 AM
Get a tight fitting pin and drill a new hole for the retaining pin. Even put some washers on it to fill the space between the "ears". The tighter the better so it not flopping around moving back and forth.
Lo-Fi Version | Time is now: 28th June 2026 - 06:54 AM |
