carreras0 |
Newbie ![]() Group: Members Posts: 2 Joined: 11-September 09 From: CA Member No.: 10,795 Region Association: None ![]() |
Hello,
Does anyone know of an archive of Porsche 914 images that would be useful for assembly? For example, I'd like to see a picture from the underside of the front fender, showing how the turn signal lights are attached. Im just reassembling now after a complete teardown over 10y ago. I added some steel fender flares. Im thinking I must have removed a metal strap to which the turn signal lights are attached. I'd love an up close picture of the brake line attachments to the calipers, and how the fittings are clipped onto the suspension parts. Is there such a database of photos of a properly assembled 914? |
Dion |
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,901 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Try browsing through the “build” challenges & restoration threads. You will prolly find something that meets your needs.
http://www.914world.com/bbs2/index.php?showforum=78 |
carreras0 |
Thanks, Dion. Ill check it out!
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,829 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
Hello, Does anyone know of an archive of Porsche 914 images that would be useful for assembly? For example, I'd like to see a picture from the underside of the front fender, showing how the turn signal lights are attached. Im just reassembling now after a complete teardown over 10y ago. I added some steel fender flares. Im thinking I must have removed a metal strap to which the turn signal lights are attached. I'd love an up close picture of the brake line attachments to the calipers, and how the fittings are clipped onto the suspension parts. Is there such a database of photos of a properly assembled 914? Try browsing through the “build” challenges & restoration threads. You will prolly find something that meets your needs. http://www.914world.com/bbs2/index.php?showforum=78 I agree there are probably several build threads that may have this documented. i am pretty sure i took and posted pictures of that area during my reassembly of that area , you can check my build thread . I dont know what page.. What are you specifically looking for, the wiring or how its mounted on the back side? Phil |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,968 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
You need the U-brackets to hold the TS buckets in place to the body. nothing is welded in.
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,854 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Recently I have been using Bring A Trailer to get nice pictures of various point of interest.
With every 914 sold there having ~100+ pictures, you can find a lot of details. Good luck with the reassembly! |
Lo-Fi Version | Time is now: 4th July 2025 - 09:42 PM |
