FS New Weltmeister 180 lb Rear Springs |
aturboman |
Jan 1 2023, 02:13 PM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
aturboman |
Jan 8 2023, 03:36 PM
Bump for lower price
930cabman |
Jan 8 2023, 06:47 PM
Advanced Member Group: Members Posts: 3,144 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Put me in line, assuming you can provide more information. Can these be used in a street application? I did a quick google search and found very little.
Thank you |
aturboman |
Jan 9 2023, 09:26 AM
Weltmeister is the original brand Performance Products owned back in the day. The 180s are good for a 914-6 or a car with wider tires and aggressive driving.
I bought this set for my 914-6 with a 3.0 engine but then realized I had already bought them so they're just duplicates. The progressive spring makes them softer for better ride but they get significantly stiffer as they compress. Hope that is enough info. PM me if you want the set. Thanks These are pending sold, thanks. |
Nacho |
Jan 10 2023, 11:38 AM
Member Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None |
JamesM |
Jan 10 2023, 03:09 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Put me in line, assuming you can provide more information. Can these be used in a street application? I did a quick google search and found very little. Thank you I have had these on my car since i bought it 20+ years ago, paired with a 21mm front weltmeister swaybar. fine on the street as long as you have decent control arm bushings. Feel like the 21mm swaybar may even be a little much for them, pushes a little more than i would like. Going to try softening up the front of the car a little when it goes back together |
B2524 |
Jan 11 2023, 11:16 AM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
Could you measure the diameter of the wire used to make these springs? Not the coil diameter just the wire. Thanks.
Aefcaf |
Feb 15 2024, 03:11 PM
Newbie Group: Members Posts: 18 Joined: 3-May 20 From: Ohio Member No.: 24,219 Region Association: MidAtlantic Region |
aturboman |
Feb 16 2024, 09:11 AM
Sorry, they are no longer available
mepstein |
Feb 16 2024, 02:45 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’m pretty sure I have a new pair of the same springs. I’ll check tonight. PM me if interested
Lo-Fi Version | Time is now: 8th June 2024 - 02:37 AM |
