Using Tangerine racing 914/6 shift kit for a Type4 with headers |
Tdskip |
Jan 18 2023, 04:19 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Yeah, like, I got kind of stupid ambitious with the number of projects that I took on so trying to rationalize things a bit here.
I have a 74 which is going to have that big type four engine go into it with headers and I think that should allow me to use the Tangerine Racing 914/6 shift linkage because the headers from Sierra Madre should let that straight linkage move freely, but I haven’t marked everything up yet. Anyone done that? Dope slaps to be administered? Thanks! Attached thumbnail(s) |
r_towle |
Jan 18 2023, 04:28 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Not sure if I am right, but ask Chris.
I think the long straight one is for a tail shifter and the bent one is for a side shifter. |
Tdskip |
Jan 18 2023, 07:47 PM
Not sure if I am right, but ask Chris. I think the long straight one is for a tail shifter and the bent one is for a side shifter. You are probably right, it’s been a year since i ordered this all. Oof. I’ll ring Chris so he can administer the dope slaps as necessary. Hope you are doing well and thanks for the response. |
mb911 |
Jan 18 2023, 10:01 PM
914 Guru Group: Members Posts: 6,863 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
The straight rod will not work with the 4cyl cross bar
ChrisFoley |
Jan 19 2023, 04:54 AM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
mb911 |
Jan 19 2023, 06:11 AM
JamesM |
Jan 19 2023, 09:32 AM
Senior Member Group: Members Posts: 1,912 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Does anyone have any data yet showing that these "headers" from bursch actually do anything other than eliminate your heat? They just look like heat exchangers without the heat exchanger and an added crossover. AFAIK they are unproven at this point. If you are interested in loosing heat there are multiple other proven header designs. |
JmuRiz |
Jan 19 2023, 10:11 AM
914 Guru Group: Members Posts: 5,432 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I was thinking the same thing, a dyno session would be the only way to tell.
Tdskip |
Jan 19 2023, 10:13 AM
Thank you for all the discussion gentlemen, really appreciate it.
I would actually be keen to figure out how all these headers work, I have a beautiful full set from Marty but they’re going to require modifying an existing muffler, and it was actually cheaper to just throw these ones on to get the car up and running. You guys are great, thanks! |
Lo-Fi Version | Time is now: 28th May 2024 - 11:34 PM |
